need electrical help
Old Dec 9, 2017 | 09:26 PM
killa bronco's Avatar
killa bronco
ok guys I have attempted to do the hardest thing ever instead of buying a new harness which might end up being the only way but until I prove defeated I need a hand . btw this is a 89 7.3 idi dash harness I'm putting into a 96 dash and attempting to keep 96 steering column
I need pinouts color and location of
wiper switch
should be black, red, white, black with pink stripe blue with orange stripe black with white stripe, fairly easy right ( I think I have this already just want to double check)
ignition switch
yellow, yellow, black with green stripe
red with green stripe
gray with yellow stripe
black with white and black with blue stripe pinned on same pin
red with blue stripe
purple with white stripe
and the c305 connector plug mine is a 11 pin plug only using 10 wires
black pink stripe
green white stripe
white with blue stripe
blue black stripe
big blue wire green stripe
white red stripe
green pink stripe
orange blue stripe
blue
green
after this I have some 96 pinouts I need . basically what I'm doing is using an 89 idi harness in my 96 truck and I'm attempting to retain all my 96 column components in a normal working fashion thanks in advance
StumpPullerF1
Appearance & Dress-Up
Jan 3, 2011 08:27 PM
charles09
Mar 16, 2010 08:56 PM
jjlogue3
Kansas Chapter
67
Jul 30, 2007 08:10 PM
gitair
Jul 23, 2004 09:09 PM
