had cooper tires they were 265 65 r18`s filled them with 44 lbs. now i have 285 65 r18`s and it says 80 lbs. why such a big jump and i only put 70 in is that ok
At 70psi you're probably still well over what you need. You ever notice how many pickup tires wear in the center of the tread? That's because they have too much air. Air down 'till you have good contact all the way across the tread. You'll likely find that it rides and handles better. If those tires are too wide for your wheels you may find that to get perfect complete contact you have to air down too far and your handling starts to degrade, at that point find a happy medium of pressure where your handling is good.
I generally won't use the max pressure unless I'm loaded heavy. All my vehicles get the amount of air they need to achieve the best tread contact. In some cases I've had to tweak it further to achieve the best ride/handling, but usually not. The manufacturer's suggested air pressure is for the factory tires and at maximum load. Generally speaking, the bigger the tire and the lighter the load, the less air you need. I run around 30 psi in my F-350 CC 4x4, it has 37" tires. At the tire's max of 50psi the ride will rattle your teeth loose and the tires would wear out in the middle because the edges won't touch the ground. When I put my extremely heavy boat trailer on I air up the rears to about 45.
