them as I going away from the chrome. I had to cut them down about 6'' and redrill the mounting points in the boards. It was quite easy and they are solid. I like them so much more than the tubes.
I used the mounts from the tube I had on it before but easy to remake. Flat bar bolted to the floorpan extended down far enough to weld the running boards to them. came out very clean and strong.
