Correct throttle stud
Old Sep 12, 2003 | 12:12 PM
bstanke39's Avatar
bstanke39
I'm making some progress in hooking up the new Holley carb (P/N 0-80452) on my 1979 Ford F-150 460 V-8 w/ AT. Morre questions:
1. What is the correct Holley P/N to re-attach the throttle? Holley lists P/N 20-37, 20-38, and 20-39, but no explanation of application.
2. I purchased the 20-91 kickdown kit, but it came with no instructions for installation. The kickdown rod connected fine to the linkage that came with the carb. Did I really need this kit, and if so, how do I install it?
3. Do I need the universal throttle solenoid (Holley P/N 46-74)? The old carb had a solenoid, which was energized when the A/C comprressor was switched on.
Thanks a bunch!
Old Sep 12, 2003 | 11:19 PM
LxMan1's Avatar
LxMan1
#3 Are you still running a/c? if not, then no.
#2 If the carb already had the correct lever on the linkage and all hooked up well, then return the kit. Not all carbs have the kickdown lever on them from the factory.
#1 The carb didn' t come with one? They usually have a small parts bag that includes the air cleaner stud, breather gasket and the ball studs.
Anyway, I believe that it is the 20-37 7/32".
Jimmy
Old Sep 13, 2003 | 08:56 AM
bstanke39's Avatar
bstanke39
Thanks for the reply Jimmy.
I will order the 20-37. The plastic bag had new carb hold-down studs and nuts, but no other hardware. I will orde the 20-37 today.
The A/C still works, so I will also order the solenoid. As you indicated previously, the vacuum hose diameters are different than the original carb, so I need to work that out.
There are two vaccum pipes that come up from the intake manifold on the passenger side. What are these for?
Old Sep 13, 2003 | 11:03 PM
LxMan1's Avatar
LxMan1
Exactly where are they located? Are they in the center next to the carb? If so, they were for an exhaust heated choke. The Holley will be electric choke, so you won't need them.
Jimmy
crazyeddie
Alternative Fuels, Hybrids & Mileage
Mar 16, 2021 06:15 AM
bigwalt1
Jul 16, 2014 08:14 PM
PapaBearYuma
Apr 1, 2012 12:25 AM
ArdWrknTrk
Aug 12, 2010 09:30 AM
Lizardking
2004 - 2008 F150
Sep 23, 2005 12:48 AM
