If that is the sensor on the dash then nothing is on it. It's still under warranty so I guess, I will let them look at it. As much as I dislike letting the dealer touch it.
That's why I used to lease and just switch trucks every year.
Michael13- My sensor has a smoke colored dome over it. If yours doesn't then that may be your problem. It's a pretty small dome- about half an inch in diameter.
The windshield refective cover I use must have built up heat between the glass and shield, then melted/fused together the sensor. I replaced it and the sensor is working.
