No fuel pressure
Old Dec 1, 2017 | 09:05 PM
Rollingscrapmetal's Avatar
Rollingscrapmetal
No fuel pressure
Ok 1990 Bronco 302 aod or aode
So here's what I've got so far the symptoms are a red engine light, new fuel pump still won't work, abs light and it won't let me pull codes
the red light evidently always came on but shut off once the thing started I'm not particularly familiar with them but I know low oil pressure can turn it on
The fuel pump quit working and the tank had a hole in it that was literally sealed with all the dirt around it so both got replaced and the new one won't kick on even by the test
abs light is probably unrelated but I'll take any advice since I've never dealt with them
as far as not being able to pull codes the check engine light shuts off like it's trying to run but it doesn't return anything no codes no nothing light doesn't ever come back on
Old Dec 1, 2017 | 09:36 PM
HuntingRat's Avatar
HuntingRat
You test the relay? You hooked up a gauge and are getting zero pressure?
Old Dec 1, 2017 | 09:46 PM
Rollingscrapmetal
I replaced the relay with one I know worked
Old Dec 2, 2017 | 12:35 PM
Conanski's Avatar
Conanski
Does the pump relay click on when the key is first turned to the run position? You may need a helper to figure that out. If it doesn't check that the EEC relay is working, because if the PCM never gets power then the fuel pumps won't either.
Old Dec 2, 2017 | 12:54 PM
Rollingscrapmetal
Eec relay was working but I didn't do that check
so that's my next step
mississippiheat
Dec 13, 2012 05:53 PM
dagray3
25
Jul 21, 2011 07:42 AM
monckywrench
Electrical Systems/Wiring
Jan 1, 2008 05:41 PM
atskuv
20
Mar 5, 2006 05:53 PM
tim_1911
Nov 19, 2001 11:46 AM
