302 engine ceased
Old Dec 1, 2017 | 12:55 PM
ryan73ford's Avatar
ryan73ford
302 engine ceased
Hi, I just swapped a new engine into my truck and during the second drive it ceased up on me. It is a 1969 289 with 302 heads on it which tells me it was rebuilt in the past. I had everything tuned well except I didn't have the oil pressure gauge hooked up. I wasn't worried because it ran so good and didn't burn anything. I ran penzoil 5w-30 in it with 91 octane non-ethonal gas and once driving I heard the engine "squeak" like a bad wheel barring and it died and hasn't turned over since. I took off the valve cover to find a rocker arm slipped off the valve spring and after tearing it down to the short block I haven't found any problems but it still won't crank over. Everything is clean and looked well oiled. Idk what could have happened any help is really appreciated thank you.
Old Dec 1, 2017 | 01:44 PM
meangreen92's Avatar
meangreen92
You should pull the main bearings and have a look.
Old Dec 1, 2017 | 02:20 PM
njdevil77's Avatar
njdevil77
I had a 351m rebuilt twice in two weeks......... The first time during the, break-in a valve head snapped off the stem and smashed between the plug and the piston, and cracked the cylinder wall........ I got nice and wet when I pulled the drain pan plug.......... I keep the dented spark plug on my tool chest as a reminder.
Old Dec 1, 2017 | 02:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No such thing as a 1969 289. 289 was cancelled at the end of the 1968 model run.
302 introduced in Spring 1968 for Ford/Merc cars, in 1969 F100, Bronco and Econoline.
Pic: Where is 1969 289? No see um.
Old Dec 1, 2017 | 04:13 PM
TheMonson's Avatar
TheMonson
Is the engine still in the truck? Maybe a flywheel bolt backed out?
tsevrens
Engine Swaps
Apr 20, 2017 05:12 PM
tiger_698
Feb 5, 2009 10:48 PM
finnly56
Nov 23, 2008 02:21 PM
Brian77Ford
16
Apr 21, 2004 03:57 AM
bgblktruk
15
Apr 29, 2002 11:00 PM
