Emblem Removal
Old Sep 12, 2003 | 12:54 AM
Fordman65's Avatar
Fordman65
Emblem Removal
Does anyone know how you can safely remove emblems without harming the paint??
Old Sep 12, 2003 | 12:57 AM
Fordman65's Avatar
Fordman65
Smile Emblem Removal
Any info would be great. Thanks.
-Aaron Griffith
Old Sep 12, 2003 | 02:59 AM
Aekisu's Avatar
Aekisu
Emblem Removal
<cr>
Depends on the emblem. On my 86 F250, they are stuck on with double-sided tape. I just used a putty knife to break them loose. If yours are the same, just make sure you don't damage the alignment pins molded into the emblem.
Old Sep 12, 2003 | 07:56 PM
vettehauler's Avatar
vettehauler
Emblem Removal
if it is the kind that Aekisu describes, you can usually take a long piece of dental floss, and "saw" it off, placing the DF on the edge, and working your way across. Yes a putty knife may be effective, but to great of a risk in scratching the paint.
Good luck
Old Sep 12, 2003 | 11:30 PM
Fordman65's Avatar
Fordman65
Emblem Removal
Is there any solvent you use to remove the adhesive? Thanks for all the imput.
-Aaron
Old Sep 12, 2003 | 11:38 PM
bob-63-292's Avatar
bob-63-292
Emblem Removal
A heat gun works wonders....
Bob
Old Sep 13, 2003 | 01:08 AM
Aekisu's Avatar
Aekisu
Emblem Removal
Good luck
Excellent idea. Never thought about using dental floss.
Old Sep 13, 2003 | 01:20 AM
Backroads_Jack's Avatar
Backroads_Jack
Emblem Removal
Just want to let you know that WD-40 works great removing the double side tape and any gumming stuff.
I found out the hard way. I had a truck with a camper on it. You know the padded between the camper and bed. Will I removed the camper and was trying to remove the tape with a razor blade and was taking hours to do just inches. Well my Dad comes out and spray WD-40 on it, and I did the rest with 3 minutes.
Something to try.
Thanks,
