vibrating in rear diff!!!
Old Sep 12, 2003 | 12:09 AM
f150on38s's Avatar
f150on38s
Question vibrating in rear diff!!!
at speeds above 15 mph when i let off the gas there is a high speed vibrating coming from my rear diff.. all bearings are fine. i just took everything out of the entire housing. the differential housing i had before was broken in two.. i don't know why. im guessing the pinion gear it or something and broke it.. its got big problems, so i had to replace it. does anyone know why it vibrates?! please help me! could the backlash be off?
Old Sep 12, 2003 | 09:58 AM
MustangGT221's Avatar
MustangGT221
Did you check the carrier run out when you installed it?
Old Sep 12, 2003 | 01:53 PM
z 97ford1's Avatar
z 97ford1
maybe it's an out of balance drive shaft
Old Sep 13, 2003 | 11:24 PM
f150on38s's Avatar
f150on38s
i found out the problem.. the ring and pinion gear had some small chips on them. i had to end up replacing both the ring and the pinion. thanks guys for all your feedback and i appreciate it alot!
Gerby Dutchy
2009 - 2014 F150
Sep 29, 2014 08:43 AM
jjmaas
Jun 14, 2010 02:26 PM
Strut61
6.4L Power Stroke Diesel
Mar 12, 2007 08:39 PM
JBB1073
Feb 11, 2004 12:35 PM
Bteter
Dec 5, 2003 09:00 AM
