Reared whine
Old Nov 28, 2017 | 02:34 PM
Cortese14's Avatar
Cortese14
Reared whine
1993 ford f250 4x4 Just purchased and rear end is whining only when foot on the gas. You can let pickup coast and no noise. I drove the pickup 60 mile to get it home. I removed pan from rear end expecting lots of metal fillings ? It was clean. I replaced oil and added a additive and no change ?
Old Nov 28, 2017 | 03:13 PM
GoinBoarding's Avatar
GoinBoarding
Pinion bearings going out?
How'd the R&P teeth look? Would have been informative to check the pattern while you had the cover off.
Old Nov 28, 2017 | 05:41 PM
Eric Fullerton's Avatar
Eric Fullerton
Worth a shot to check the pinion shaft, see if you can wiggle it. If you can it might be as easy as re-torquing it, or as complicated as putting in a new crush bushing and setting it up like new gears. Worth a shot, just don't get carried away or you will have the second scenario. Look to see if the pinion seal has been changed recently, not hard to screw that up and leave it too loose. It takes an effort to screw it up by getting it too tight.
Amicus
Aug 24, 2016 10:50 PM
Bananarama
Sep 19, 2012 03:02 PM
Noggins_1500
Feb 22, 2005 03:14 PM
