1979 Heater Box
Old Sep 11, 2003 | 09:43 PM
Fomoco1546's Avatar
Fomoco1546
1979 Heater Box
Hi, I have a 1979 F-250 pickup. When I run the defrost I don't get much air up to the windsheild. After checking out the problem, I discovered that there is a 3/4 inch gap between the air defrost duct and the heater box. I assume there should be a seal in there, but I don't see one listed in my shop manuals. I also don't see how the defrost duct attaches to the heater box. Thanks Gary
Old Sep 11, 2003 | 09:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
1979 Heater Box
Could it just have come loose? Maybe a little shrinkage over the years?
Do you hace AC or is your truck heat only?
Old Sep 11, 2003 | 10:02 PM
Fomoco1546's Avatar
Fomoco1546
1979 Heater Box
I don't have AC just heat. I can't pull the two together. I looked at two other 79's one had a gap, and one was tight together.
Old Sep 11, 2003 | 10:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
1979 Heater Box
Sounds like a job for duct tape...
Old Sep 26, 2003 | 03:20 PM
plowpusher's Avatar
plowpusher
it has a foam spacer about 1 1/2 to 2 inches thick that is cut to the shape of the top of the heater box and glue to either the duct or heater box the duct work hangs from 4 screws inside the duct at the dash
