1985 f250 38 gallon rear fuel tank project
#31
Thinking i mite use (layered) flexi seal were the factory used rubber strips between the skid plate and tank.
I cut it in strips to fit between the tank and straps and where the tank hit the holders on the frame.
The back of the rug was black so I put the green grass side to the tanks.
Being plastic like it should not hold water and not fall apart like some other stuff one might use.
Dave ----
The following users liked this post:
#34
#35
Hi Olds64,
Shall do. It may be awhile.
Ol'blue has front end issues. Wont do anything above 50 mph and dosent hold any any oil in front differential.
haven't decided if i am going to do it or have the local shop do it. Probably have the shop do it.
then i can finally license it.
#37
Check out this site for that vent valve gaskethttp://broncograveyard.com
i broke down a spent $22 on one from the local ford dealership Andersons ford. If i had one shipped it would take a week and i would only save a few bucks. Thank you though.
#38
I would like to correct something I said earlier in this old thread. I said you can take the upper straps out, and swap them to the bottom. You can, but I found out it puts the tank up against the bottom of the bed. That's not a real problem until you take the bed off. I think it's best to leave the upper straps in place, and get some more straps for the bottom. I think someone mentioned that in another thread on these tanks, but unless I missed it, it's not brought up in this thread.
#39
#40
Hi Olds64,
as requested I am reporting on the rear 38 gallon tank conversation. It's been a few of years since I did the conversion and I will have to say it's one of my top two favorite upgrades. Favorite being the lockers front and rear.
the 38 gallon rear tank is a great low buck upgrade. I highly recommend it.
#42
They seem to only make a diesel tank. Has anyone seen otherwise?
#43
for the 80 86 the tank should be the same gas or diesel. The senders will be different depending on your fuel system requirements.
#44
terrylamar
49
08-12-2016 11:06 PM
4EyedTurd
12-20-2012 11:49 PM
SilverSport
06-10-2006 04:56 PM
