Shift Boot issues/replacements
Old Nov 26, 2017 | 05:58 PM
SonofaFord's Avatar
SonofaFord
A while back I had to do a "in the field" repair of my shifter, because the thing it plugged into broke. So I welded it back up and reinstalled it. I seem to remember some kind of "lower boot" or shield that was under the main rubber boot. Does that ring a bell to anyone? Well since then I have gone through two rubber shift boots pretty quickly. They just keep coming apart. Does anyone know why this would be or are the quality of replacement rubber parts just getting that bad? Thank you for the ideas!
1978 F150 Custom, 300 I6, T170 SMOD "3+1" trans.
Old Nov 27, 2017 | 01:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I seem to remember some kind of "lower boot" or shield (weather pad aka dust shield) that was under the main rubber boot.
1978 F150 Custom, 300 I6, RUG SR-OD Single Rail 4 speed Overdrive trans.
D1TZ-1011230-A .. Transmission Cover Weather Pad / Obsolete ~ Reproduced?
1971/79 F100/250 2WD & F350 4 M/T / 1971/79 F100/250 4WD with NP435 4 M/T
No Ford dealer or obsolete parts vendor has any.
Old Nov 27, 2017 | 04:11 PM
F350moneypit's Avatar
F350moneypit
Novak has a mini boot for the NP 435 that might work in your application. goes right on top of the shift tower...
https://www.novak-adapt.com/catalog/...s/np435-parts/
Old Nov 27, 2017 | 06:56 PM
7636074460's Avatar
7636074460
I'm not sure if you mean between the transmission and the The Shifter Boot that is on the interior of the cab? I just fill this space with a spare piece of cab floor insulation (the type thats made of what looks like blue jean dryer link with heavy reflective tin foil) and it has stood the test of time to keep dust and noise out.
Old Nov 28, 2017 | 09:52 PM
mark-guiver's Avatar
mark-guiver
Yes the aftermarket shifter boots are that quick to shred. I only wasted the money on 1, then went to the Pull and Pay and grabbed a couple of OEM boots from a few Fords to see which one fit best. Chose the one that worked best, problem solved.
Mark.
cdouglas75
Jun 22, 2016 08:35 PM
60'_f100
Feb 6, 2015 03:44 PM
tracer3612
Oct 2, 2014 10:05 AM
sonny1965
May 25, 2014 06:45 PM
Queueball
Feb 1, 2013 02:01 PM
