6.2L V8 Discuss the 6.2L V8
cold start issues
Old Nov 23, 2017 | 07:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
cold start issues
on my 14, now that it is getting colder i am having starting issues.
it will fire rite up, but when i put it in gear it will die, almost like it is running out of fuel. it usually restarts, but twice i had to step on the gas to get it to start and it ran like crap. then i have to get it in gear and feather the gas to get it running. once moving it is fine.
any ideas?
truck has 97,000 miles on it. plugs were changes when i got it at 94,000 miles
i don't know if this has anything to do with it, but this thing only gets 8-9 mpg town driving and 12-13 out on the road.
2014 F-250 4X4 supercab shortbed with 3:73 gears and stock 18 inch tires and a 5 star economy tune.
in stock tune it only gets 6-7 in town triving
Old Nov 23, 2017 | 08:16 AM
Chuck's First Ford's Avatar
Chuck's First Ford
I would start with looking at vacuum hoses... cracks or little holes...
or a vacuum leak at throttle body...
Old Nov 23, 2017 | 08:18 AM
Slowpoke Slim's Avatar
Slowpoke Slim
Wow, that's pretty crappy mileage. I take it it doesn't throw any codes? Did it have cold start issues last year too? With the stock tune in it, does it have cold start issues (I know the mileage is worse)?
See if maybe 5 Star can send you another tune?
Sounds like something's seriously screwed up in your fuel metering.
Old Nov 23, 2017 | 08:55 AM
tjc transport
i ain't rite
it does have a bad passenger hub seal.. but that would only cause vacuum leak when 4X4 is engaged correct?
not sure on what it did last year, i got the truck end of january and had the plugs changed first thing.
then had the cats changed because the bad plugs burned out the cats.
the 5 star was to compensate for the high flow cats throwing a cat efficiency code.
since putting the 5 star in, i have not had any codes except for when the driver side manifold to cat bolts loosened up. changed the studs and cleared that code and all is good again.
this truck really don't get used much, 4 miles one way to and from work 2-3 days a week..
and an occasional 11 mile run one way to and from the old body shop.
the only reason i drive the truck instead of a car is because it is easier to get in and out of.
in the past 10 months i have only put 4,700 miles on it.
Old Nov 24, 2017 | 06:23 AM
tjc transport
i ain't rite
this morning at 26 degrees i used the remote starter and let it run for about 1 minute before getting in it. it drove rite away without any hesitation at all.
Old Nov 24, 2017 | 08:14 AM
tibadoe's Avatar
tibadoe
I would think the "5 star economy tune" needs fine tuning or update.
Old Nov 24, 2017 | 11:59 AM
tjc transport
i ain't rite
it ain't the tune, cause it does it in stock tune also. and in stock it only gets 6-7 mpg.
Old Nov 24, 2017 | 12:38 PM
Ron94150's Avatar
Ron94150
Are you using the tuner to pull codes? If so, I would take it to a dealer or shop with dealer software to pull codes.
Old Nov 24, 2017 | 02:43 PM
tjc transport
i ain't rite
i have a sct programmer with 5 star tunes loaded into it. it does not pull codes. and there are no codes in the truck according to autoenginuity, torque app, or the autoXray scanner.
Old Nov 27, 2017 | 04:08 PM
tjc transport
i ain't rite
anyone know what the vacuum should be? i am reading 25 inches at idle on the torque app.
johnfist
Modular V10 (6.8l)
Apr 26, 2019 07:53 AM
LFPENN1974
Jun 21, 2016 10:20 AM
Chuck999
1997 - 2003 F150
Mar 5, 2013 02:20 PM
dancraig
26
Aug 17, 2012 10:29 PM
wojtek9321
Jan 22, 2011 11:56 AM
