high idle problem IAC?
Old Sep 11, 2003 | 07:28 PM
nick11082001's Avatar
nick11082001
my 1987 Ranger with a 2.9L engine started to idle way too high a friend told me that its the IAC, but i dont really know for sure, and would like to know what you think the problem is so i know if i should replace this part or not. any help will be appreciated thank you
Old Sep 11, 2003 | 09:01 PM
Ken00's Avatar
Ken00
It could be the IAC stuck open but a vacuum leak will also cause a high idle.
Old Sep 11, 2003 | 09:21 PM
nick11082001
if this is any help, before it started idling too high, when the engine was cold, it was hard to start, and would run rough til it warmed up, almost like the choke wasnt working, but with this being a 2.9 FI i know there isnt any choke, and the IAC takes its place, so could this further narrow it down that it is the IAC?
i need to fix this asap, i dont have the money to sent it to a mechanic, and im moving to Kentucky very soon
Old Sep 12, 2003 | 02:40 AM
TJ-Ranger's Avatar
TJ-Ranger
Having the same problem. Had the IAC cleaned a couple of times..and then lastly, when re-installing it, tightened it down real good. That helped a bit..but still idles high..and the idle screw is down as far as it goes. Looks like my plenum or upper intake manifold gasket has a small leak. So its loosing presure. Having that fixed tommor or Sat. Hope that works.
Old Sep 12, 2003 | 06:51 AM
nick11082001
in the long run, if i cant get this fixed right away, will the high idle affect anything besides possibly gas mileage?
Old Sep 12, 2003 | 09:50 AM
Ken00's Avatar
Ken00
I don't think it will hurt anything.
The hard starting could be related to a vacuum leak causing a lean condition, check all your hoses first.
Old Sep 12, 2003 | 10:47 AM
Richie T's Avatar
Richie T
I had a 1988 Nissan 200SX V6 and the IAC went bad on it -- sounds just like your problem. Hard to start and ran rough until warmed up and then idled high just like a choke problem. I replaced the IAC and it was fine.
Good luck!
Old Sep 12, 2003 | 08:10 PM
nick11082001
thank you all, i just replaced the IAC, and it works fine, thanks again for the help
God Bless
