Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2012 Escape missfire
Old Nov 19, 2017 | 01:35 AM
Rus01's Avatar
Rus01
My dad is having problems with his his escape with a miss.
He got it scanned and they said #5 is missing.
He replaced the plug and the coil and still no difference..
Its a 2012 Escape with a V6
Old Nov 19, 2017 | 11:02 AM
ajwgator's Avatar
ajwgator
Must not have been #5. Have it scanned again. How many miles are on it? Usually it is always one of the coils that causes the misfire. If it has more than 100K on it you may as well do all six coils and be done with it. You can get all six for about 32 bucks on ebay with free shipping. Need to go on and get an intake gasket set so you can replace the gaskets because to get to cylinders 1,2,& 3 you have to take off the top section of the intake. Its really not a complicated task.
Old Nov 19, 2017 | 07:34 PM
5_labsownus's Avatar
5_labsownus
I would have it re-scanned and see if it still indicates cylinder 5. If it does with a new plug and COP, it is possible the injector on that cylinder has failed.
Rod
Old Nov 20, 2017 | 08:44 AM
Rus01's Avatar
Rus01
Thanks guys, I’ll get him to rescan it and see what it says now
Old Nov 20, 2017 | 02:07 PM
simonsi's Avatar
simonsi
...and make sure #5 was actually changed, easy to get confused which is which.
Old Nov 20, 2017 | 07:20 PM
Rus01's Avatar
Rus01
Ok.. he had it rescanned today and now it’s saying #5 and #2 vacume leak.
im guessing this could be the intake gasket or a cracked intake?
Old Nov 20, 2017 | 07:33 PM
simonsi's Avatar
simonsi
Ok this is getting confusing, I didn't think it could tie a vacuum leak to a single cylinder but I may be wrong - what are the actual codes please?
#5 is the centre front - that was changed out yes?
#2 is centre rear
No need to disturb the intake manifold (and hence gaskets), to change #5 - which makes it odd its now throwing an issue with #2 - yes the gaskets can cause an air leak.
The cylinder layout is
Rear
1. 2. 3
4. 5. 6
Front
Old Nov 20, 2017 | 09:08 PM
5_labsownus
One thing to check is the emission lines between the valve covers and intake tube. the elbows get soft and leak. But this most often makes a very poor idle and no power and multi random misfires not a given cylinder/s.
ericash25
Modular V10 (6.8l)
Apr 27, 2018 07:37 AM
briank
1997 - 2003 F150
Sep 26, 2010 09:30 PM
natethegreat_2005
1997 - 2003 F150
13
Apr 17, 2008 11:52 PM
Rynofasho
Oct 12, 2007 09:57 PM
swhiteskunk
1997 - 2003 F150
Jul 23, 2007 04:58 PM
