2012 Escape missfire
Must not have been #5. Have it scanned again. How many miles are on it? Usually it is always one of the coils that causes the misfire. If it has more than 100K on it you may as well do all six coils and be done with it. You can get all six for about 32 bucks on ebay with free shipping. Need to go on and get an intake gasket set so you can replace the gaskets because to get to cylinders 1,2,& 3 you have to take off the top section of the intake. Its really not a complicated task.
Ok this is getting confusing, I didn't think it could tie a vacuum leak to a single cylinder but I may be wrong - what are the actual codes please?
#5 is the centre front - that was changed out yes?
#2 is centre rear
No need to disturb the intake manifold (and hence gaskets), to change #5 - which makes it odd its now throwing an issue with #2 - yes the gaskets can cause an air leak.
The cylinder layout is
Rear
1. 2. 3
4. 5. 6
Front
#2 is centre rear
Rear
1. 2. 3
4. 5. 6
Front
