302efi to 351w carb swap
you'll have to change or modify your y pipe cuz the 351 is wider, you'll have to use the starter and flywheel off the 302 if you keeping the manual trans, other than that everything else will drop in place, if your going to a carb i'd just eliminated the computer altogether and use manual gages, and change it to a duraspark II ingnition or aftermarket. Just my 1 1/2 cents! DW
