I just graduated from high school and with my graduation money I bought a badass Highboy from a family friend. My first truck was a 76 chevy so I'm Fairly unfamiliar with fords. It's a 75 F-250 and the previous owner had it sit for 19 years. 19 years ago he swapped the previous motor out of it and put a decently built 460 in it and swapped the 4 speed out and put an automatic transmission in it and since I'm unfamiliar with fords I don't know what transmission it is. But he would start the truck once a year and said he'd never had transmission problems with it. After I got it running good I took it out for a spin and the tranny slips. When he put the auto tranny in he threw in one of those awful B&M ratchet shifters and it's super loose. I'm sure the linkage is sloppy. Could this be what's causing the slip? What else could it be? I changed all the fluids and I've checked that the fluid was full multiple times. Sorry if this a lengthy post, I'm new to forums
Setting for 19 years is about the worst thing that can happen to a truck and a trans.
Look at the trans pan pattern...probably a C-6. B&M shifters are cable operated, so that is probably not your problem.
Have you checked the vacuum modulator (on the side of the trans) rubber line condition and for fluid? There should NOT be fluid in that line. Replaced the vacuum modulator itself? Then dropped the pan and replaced the filter/fluid?
Just starting a truck once a year is not a true assessment of the trans condition. Unless he says he started and drove it around.
Drive it around the block a few times and then check the fluid, over the years i've probably bought a handfull of trucks with "bad transmissions" that ended up being a fluid problem.
Most recently a 78 Bronco that needed the "transmission rebuilt" because it wouldn't move after sitting for some time. It would only surge forward in first if you got on it. Put fluid in it, it moved, but leaked bad from the trans pan gasket. New gasket and fluid and it would drive without issue. $30 fix is easy compared to a transmission rebuild.
He said whenever he would start it he would drive it around and tear up his field but never for very long. I'll be sure to check the modulator and that line thanks
I did change the fluid and the filter and I've drove it about a quarter mile and back to my house and checked the fluid and it was full
Check the vacuum modulator and the line that goes to it. Check the line for kinks or other problems (dry rot), make sure it hasn't come off. If the line checks out, take the line off where it connects to the modulator. If trans fluid leaks out, its bad. If no fluid, it still could be bad. They're simple to replace, disconnect the vacuum line, remove one bolt that holds the clamp in place and the modulator comes out. It has an o-ring seal.
Modulators are identified by the color of the stripe. Pretty much the "go to" one is the black stripe. If they don't show that one in the catalog, go with the green stripe. Avoid the pink stripe. That one is a dual diaphragm version that has two vacuum line going to it. If by chance you have one of these, replace it with one of the other two and use the vacuum line that goes to direct manifold vacuum, cap the other line. When you pull the modulator out, be careful. There is a pin that goes in the modulator. Sometimes it comes out with the modulator, sometimes it stays in the tranny. If it comes out, don't lose it.
Slipping? What gear? 2nd in a c6 is a band, if out of adjustment, slipping is ordinary. adjust band. assess/probably change fluid. Does it feel to be a slipping in the torque converter, or in the clutch packs? like does rpm flash the stall like a torque converter, or does it slip under load, like a clutch pack? does it lock up in any gear? or slip all the time?
Well I've never really had tranny problems so honestly I have no idea what any of those few like. It will slip from first going into second but I usually drive it only far enough to need those gears. With the distance I'm driving it it should be shifting into 3rd at the highest but it doesn't shift to 3rd. I can rarely get it into reverse. When I drove it home from where I bought it (about 7-10 miles) It was shifting and I drove it on the highway at about 50-55 but once I got about 6 miles in I believe the tranny started to overheat and I lost power so I stopped and let it cool for a little. Then on the way up the hill to my house (about a mile from where I sat) it lost so much power that I couldn't keep going and the truck died in the middle of the road. Like I said I don't know much about transmissions so could this be from the tranny?
It sounds like you have a few problems. When you say you "lost power", what do you mean? The engine quit? Or the engine kept at rpm and the truck wouldn't move? If the engine is losing power then you have to fix that first before you can really see if there is a transmission issue! 19 years dormant is usually not very good for mechanical things! Where are you located, maybe there is an FTE member near you that can offer some assistance with tracking down your issue?
Good luck young sir!
Sorry for the late post I forgot all my login info. But I got all the problems figured out except for the tranny. I've checked all the vacuum lines and correctly adjusted the linkage but it still slips. I did some research about the vacuum control module going bad and I have a lot of the same symptoms described in the articles so I plan on replacing that. But I also talked to a friend of a friend who knows a bit about the C6 trannys and he said that most of the time when they start slipping theyre pretty much toast. I was wondering if that was true or not. I really hope not
Probably true, but the hardest part is removing and reinstalling the transmission. I hear that they're actually pretty easy to rebuild, with snap-ring pliers being about the only not-so-common tool needed.
Tyler, your C6 sounds like most tired C6's...... Put a new Modulator on it and see how she acts, but most likely its tired and showing its age. Ive done a lot of reading and monitoring of C6 posts and they seem to be fairly consistent with the following behaviors of which my transmission is displaying....
Cold Morning sickness - Slips, hesitates for the first few shifts after cold start Long stretch to next gear when cold - takes more speed and gentleness on the accelerator when cold in order to shift into 2nd and 3rd when cold Upon warm up, all is well - After shes warmed up and got some miles in, all is well as if nothing ever happened .....
Ive also gathered that unless there is a catastrophic failure of your C6, it can run under the above circumstances for a very long time without rebuild...... Now that being said, im talking myself into rebuilding mine this summer , its less about the money and more about I dont trust anyone with my stuff anymore..........
Have you drained the fluid ? was it black and nasty ? If so, its worn and needs some luvin...
yup fluid has been replaced along with the filter and I've checked the level countless times. Going to the parts store today to get the modulator and throw that on there and then drive it around for a while and see what happens
My C6 was having the same symptoms, It was fried. I was pulling bushes and shrubs from around my property with a 230,000mi transmission. I guess that would do it. Time for a rebuild, cost me a little over $800 to get it done.
