1989 Ranger
Old Nov 16, 2017 | 06:40 AM
ptofimpact's Avatar
ptofimpact
1989 Ranger
I bought the radio removal Tools, have the ashtray removed, see the 2 screws behind the ashtray holding the Bezel on, my question is, are/is there any other screws/fasteners/pieces need be taken off/out in order to remove Bezel?
Thanks
Old Nov 16, 2017 | 11:27 AM
Josh S's Avatar
Josh S
Just those 2 screws you found then a lot of plastic 'snap-in' points. I usually start at the ash-tray and work around counter clockwise pulling the cover out one snap at a time finishing with the one's on each side of the steering column (both of those at the same time). If you happen to be putting in an aftermarket radio, and you may already know, but many stores sell wiring adapters to make almost any brand radio plug-and-play.
Welcome to the forum,
Josh
Old Nov 16, 2017 | 12:59 PM
ptofimpact's Avatar
ptofimpact
Josh, many thanks appreciate your expertise and time. Didnt want to start yanking on the bezel and break it
Do I need any special removal tool?
Old Nov 19, 2017 | 03:08 PM
ptofimpact's Avatar
ptofimpact
Headlight ****
Can anyone tell me how the Headlght **** is removed in the 1989 Ranger, need to remove to take Dash Bezel off
Old Nov 21, 2017 | 06:32 AM
Josh S's Avatar
Josh S
There should be a little metal tab on the underside of the **** that you can push (away from the dash) with a small flathead screwdriver while gently pulling on the ****. I'm 90% sure that's how yours comes out but it's been a few years since I've worked on a 2nd gen dash.
Old Nov 21, 2017 | 07:05 AM
ptofimpact's Avatar
ptofimpact
Many thanks again for your Time, expertise, and Patience, much appreciated~
BLADE35
Aug 26, 2013 09:17 PM
FirstTry
Mar 4, 2007 05:30 PM
Jrstera
May 30, 2004 09:08 PM
krasherrr
Jun 7, 2001 08:25 PM
krasherrr
Jun 4, 2001 03:44 PM
