5R110 transmission Cold fluid exchange
on
What, buy the fluid? I got my last bag @ Rock Auto but any parts store should be able to order it. And it is a 6 gallon bag, not 5. By the bag is about half price vs buying quarts retail. And no one store I have found stocks enough transmission fluid of the same brand & type to do a full fluid exchange.
The following users liked this post:
on
THAT is also awesome (as well as all the cross posts you'd done) because this is about the slickest "how-to" I've seen in a long-time... especially for something that is hard to do, not done right at the local dealer, and critical to longevity.
Bolt size
They are metric, but the new bolts measure about 1 1/4" thread length.
Frank
The safest way to avoid cross threading is to remove one factory pan bolt and find a nut that fits it, then use the same nut on the new bolt. Be sure to run the nut all the way down both bolts to be double sure. Temporarily removing one bolt from your pan won't cause any leaks and can be replaced with no harm. Torque on the 5R110 is 11 ft lbs.
Frank
Frank
#29
#30
