1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
5R110 transmission Cold fluid exchange
Old 11-17-2017, 08:37 AM
oxt127's Avatar
oxt127
oxt127 is offline
Originally Posted by Sam I Am
For anyone that does this at home, it is much cheaper and more convenient to buy transmission fluid in the 5 gallon bag than per quart. And with the method shown in the video, seems like the intake tube could be connected to the bag and do it all at once.
Ok, you have my attention. Where do you do this?
Old 11-17-2017, 09:11 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
What, buy the fluid? I got my last bag @ Rock Auto but any parts store should be able to order it. And it is a 6 gallon bag, not 5. By the bag is about half price vs buying quarts retail. And no one store I have found stocks enough transmission fluid of the same brand & type to do a full fluid exchange.
The following users liked this post:
Old 11-17-2017, 10:09 AM
geekwithoutacause's Avatar
geekwithoutacause
geekwithoutacause is offline
Do they sell Mercon V in 6 gallon bags ? Didn't know they had this. Good tip !
Old 11-17-2017, 11:36 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Yes, and motor oil too
Old 11-17-2017, 11:55 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by Mark Kovalsky
Frank, that's brilliant! I wish I would have thought to do that.
Added to the tech folder in the Ex forum.
Stewart
Old 11-17-2017, 12:54 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Stewart
THAT is also awesome (as well as all the cross posts you'd done) because this is about the slickest "how-to" I've seen in a long-time... especially for something that is hard to do, not done right at the local dealer, and critical to longevity.
Old 11-17-2017, 02:32 PM
wedge542's Avatar
wedge542
wedge542 is offline
What we needed,i ask the mod over on the 6.0 side to add also, glad you shared the video.
Old 11-17-2017, 04:59 PM
Im50fast's Avatar
Im50fast
Im50fast is offline
Do they make Mercon SP in 6gallon bags?
Old 11-18-2017, 04:58 AM
CollinsCD's Avatar
CollinsCD
CollinsCD is offline
Does anyone know what size the pan bolts are so when I go to buy longer ones?
Old 11-18-2017, 06:08 AM
divideoverflow's Avatar
divideoverflow
divideoverflow is offline
This is great! I'm assuming it is the exact same process for the 6R140? Does anyone know if the intake tube size is the same?
Old 11-18-2017, 12:23 PM
Syncrosmash's Avatar
Syncrosmash
Syncrosmash is offline
Bolt size
The safest way to avoid cross threading is to remove one factory pan bolt and find a nut that fits it, then use the same nut on the new bolt. Be sure to run the nut all the way down both bolts to be double sure. Temporarily removing one bolt from your pan won't cause any leaks and can be replaced with no harm. Torque on the 5R110 is 11 ft lbs.
They are metric, but the new bolts measure about 1 1/4" thread length.
Frank
Old 11-18-2017, 02:40 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Received 3,392 Likes on 2,089 Posts
Added to the 6.0L forum Tech Folder
  #28
Old 11-20-2017, 05:02 AM
CollinsCD's Avatar
CollinsCD
Frank
Thanks Frank.
  #29
Old 11-20-2017, 05:05 AM
CollinsCD's Avatar
CollinsCD
One other thing I noticed is that the video says 3/4" ID tubing. Looking at the filter for my truck, I think you really need 3/4" OD tubing.
  #30
Old 11-20-2017, 08:40 AM
Syncrosmash
It's 3/4 OD,
Frank​​​​​​​
Quick Reply: 5R110 transmission Cold fluid exchange
