I know one thing my truck doesn't do that I wish it would, is the turbo vane sweep. You might want to pm Toreador_Diesel -- he's very knowledgeable on the various flash levels, mixing and matching, etc...
I don't know if the answer is as simple as get the latest flash...
Just got it done at ford dealership... tranny revs much higher to switch 1-2 and 2-3 shifts. Acts like good like tow haul tune. Other than that, power feels good. It fixed an issue I was having with the pcm not communicating with the EGR valve. Also fixed my tow haul light on dash. They flashed the PCM, TCM, and FICM. I had the 40hp FICM tune from FICMREPAIR.com, but they o
verwrote it with the reflash. Honestly, runs way better now. Tranny used to be boggy as hell for upshifts and my SCT custom tunes did not like to work with the FICM tune. Feels good as new just stock. Hope that helps.
Just to be clear, anyone including outlaw have the version for reference? I know when I had mine done several years ago from the original stock tune, I didn't feel any difference, nor did it affect fuel mileage. Still 19 mpg on the road empty, running at 2,000 rpm's max.
Orangeoutlaw: I see you are also in NorCal -- which dealer did you take it to and did they charge you (how much)?
I ran my VIN and see there is a recall outstanding for something in the front end, so I think I might take it in for that. My best luck has been with Future Ford in Roseville...
Thanks,
Scott
On Edit: Holy Crap! I called that dealer and they wanted $350 to update all three modules to the latest versions!!! So can Indy shops do this as well, or does it have to be a dealer...?
Well one thing I confirmed is NOT to take it in to my closest dealer! I figured I'd call around and get estimates. This is the dealer that couldn't diagnose squat while the truck was under warranty (whereas the earlier mentioned dealer ID'd 3 oil leaks within an hour and a half of having the truck, one being the bedplate).
So I call local dealer (Auburn Ford) and you guys will get a kick out of this: I get transferred to a service writer and tell him I want the PCM, TCM and FICM brought up to the latest flash versions. He says: that's about $125, but I don't think we flash anything but the PCM (huh?), tells me there are 2 styles of "fickems" and they have the flash they have (huh?) I tell him I have the late style, but it doesn't sway him. It gets better: he asks why I want the updates, so I tell him about how the turbo vanes got stuck so I want the strategy that does the vane sweep.
He says: I don't want to be a downer here, but it is a waste of money to do the flash, once the vanes stick even just one time, we need to replace the turbo (huh?!!!). I tell him the turbo was cleaned about 6k miles ago and it is running great right now. His reply: yeah, we used to clean the turbos but that too is a waste of time, once they stick it's time for a new one...
Of course I booked an appointment for as soon as possible!
Can't believe my FTE brothers didn't tell me I need a new turbo!!
Thanks guys - I really appreciate the help. Had I only known -- I would have saved so dang much money stockpiling all this oil! and filters!
So a couple questions for you helpful gents:
Would a new turbo come "free with an oil change" (you know, like free tire rotation)? Otherwise I'll have to buy the turbo separately, where I could just wait for my next engine swap, 'er, oil change and get both done.
Next question: I went and put on the 6.4 trans pan and filter and changed the oil when I did that. I'm assuming now that was a mistake and I should have just gone to Auburn Ford and asked them for a trans oil change, which the new oil would come in the new trans, and hopefully have the updated pan on it?
Lastly: what option do I need to ask for on my next oil change, to get the spare valve cover bolt in the HPO sump? And will that automatically mean they'll put in partially failed or soon-to-fail lifters? Maybe this last one is a Q for Jack...
Man I am SO glad I am on this site!!! Thank you all!!!
Shoot I almost forgot I was going to put the '08 rear diff cover on... I need to ask the dealer to change the oil in the diff
Scott, I didn’t ask the version of the flashes. They charged me $330 for two hours to diagnose my egr problem, and that’s it. I asked if they would throw in flash on the truck for $330. Service writer Rob here at Hansel Ford in Santa Rosa hooked me up. And my suspicions were correct in that the Re flash fixed my egr connection problem, thus allowing me to pass smog. Rob said the flash would have been $165. If you’re in the area try Hansel Ford.
On your turbo issue, I’m not sure that this flash has or has not turbo vane movement at idle. If you have a Scanguage, look up codes for VGT, input them, and watch your VGT values move up or down. That will tell you if it’s moving or not. I’ve had a stuck turbo before and the truck was so gutless you could barely drive it. Also sounded like a bogging big block gas motor (no turbo whistle once so ever). And yes, they only replace and don’t clean them now.
I also had my tranny hot flushed at dealer just a couple months ago. They said they don’t remove the pan because if it’s not leaking and has never been removed, don’t mess with it. Otherwise it will leak. - Nate
Thanks Nate. I have Torque Pro and set up a data capture for VGT % and a few other things (after it unstuck) -- definitely nothing like a vane sweep going on.
Did your paperwork tell you they updated the firmware on all 3 modules? It seemed like the one place knew about updating all 3 and the other was hopelessly clueless. It still seems to me they are just hooking up their computer and punching a couple buttons and then walking away to do more valuable things -- so $350 for that sounded high...
My truck is so low miles there is no way the turbo, or its unison ring, is worn out - I think mine stuck due to carbon build up...
