Sponsored by: Real Truck
Definitive Long Thread Question
Old Nov 13, 2017 | 10:01 PM
maticuno's Avatar
maticuno
From everything I've researched, 2002 and earlier Triton engines had the 4 thread spark plug heads and 2003 and after had the 8 thread heads. I haven't been able to find any definitive information on when exactly this change took place. Was it model year 2003 or build date 2003? What month? My engine label says October 2002 at the Windsor plant, truck is a model year 2003.
Old Nov 15, 2017 | 10:28 PM
maticuno's Avatar
maticuno
Anyone? I doubt the dealer would be able to tell from a VIN check...
Old Nov 16, 2017 | 12:48 AM
Sam I Am's Avatar
Sam I Am
Why does it matter?
Torque the plugs to 28 pounds and you won't need to worry about it either way.
You could look at them with a boroscope to know for sure.
Old Nov 16, 2017 | 01:15 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by Sam I Am
Why does it matter?
X2
The plugs can still loosen and blow out with 8 thread heads.
I saw the following from another thread:
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all 4.6/5.4/6.8)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
Old Nov 16, 2017 | 01:26 AM
Mike189677's Avatar
Mike189677
The best we’ve been able to nail down so far is that the job 2 03’s have the 8 threads. Form your engine tag date I’m guessing the truck was also built either in October or November of 02. So still pretty early in the 03 model year. You can enter your vin into etis https://www.etis.ford.com/vehicleReg...r3.eccvas1900f if you want it won’t tell you how many threads are in the head but it will tell you if it’s a job 1 or 2 or how many ever jobs the were for your model year. Dealer would have no idea. The best way to confirm would be the the borescope like Sam mentioned if I was betting on it though I’m putting my money on 4. Edit I didn’t see the list before I posted- If the list posted above is true then you mixed the 4 extra threads by a month.
Old Nov 16, 2017 | 08:26 AM
maticuno's Avatar
maticuno
Why does it matter?
I had a 5.4 F150 that spit plugs, I'm just trying to gather as much info as possible before I dive into the plug replacement on this beast to avoid that nightmare. I've also read conflicting things about using anti-seize since it can cause a false torque reading and I'm trying to factor for a margin of error.
Thank you everyone for the info so far.
Old Nov 16, 2017 | 10:34 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by maticuno
I had a 5.4 F150 that spit plugs, I'm just trying to gather as much info as possible before I dive into the plug replacement on this beast to avoid that nightmare. ...
How many miles on the plugs when they spit and what torque?
I change plugs/boots at 50k, use nickel antiseize, torque to 25ft-lbs and check torque one more time at 10k.
No problems on our 2003 at 170k.
Bought our 2002 2 years ago and it blew an OEM plug at 108k just before I was going to change them.
All the bank 1 plugs were a tad loose.
The Denso boots – 671-0001 ($30/10 ebay) work great.
kawi46
Feb 24, 2011 09:20 AM
02F250SCSD4x4Dgo
Modular V10 (6.8l)
Jan 30, 2009 01:36 PM
93F250
Modular V10 (6.8l)
Mar 24, 2008 08:18 PM
E350North
Modular V10 (6.8l)
Feb 14, 2008 12:46 PM
