NP205 Missing Snapring
Old Nov 9, 2017 | 01:33 PM
Ford77Pickup's Avatar
Ford77Pickup
I’m currently in the process of rebuilding my transfer case and one thing. I noticed before tear down excessive yoke play in and out. Apon further research I found that apparently i am missing the snap ring the hold the output shift and bearing together. I’m about done with the rebuild and all I need is this snap ring and can’t find it anywhere.
Does anybody know where I could get one or does anybody even have a parts case they could get me a snap ring off of and ship it? I’ve check everywhere online but can only find snaprings for the GM cases and those snap rings are to small.
This is the last piece of the puzzle and if anybody can help me out it’d be greatly appreciated. The shaft Diameter is 1.25”. Thanks.
Old Nov 9, 2017 | 03:14 PM
jakeharp's Avatar
jakeharp
Contacts...
Here are some contacts for shops that sell rebuild kits for the np205, they may be able to just throw a snap ring in a envelope for ya for a few bucks.......
Offroad Design
484 County Road 113
Carbondale CO 81623
970-945-7777
Drivetrain.com
800-216-1632
702-876-3100
JB Custom Fab
jonb@jbfab.net
503-749-3099
Old Nov 9, 2017 | 05:22 PM
burnthelight88's Avatar
burnthelight88
I know I have outer snap rings for all the bearings from when I rebuilt mine over the summer. I don't think I have any that will fit your shaft, but I'm replying to remind myself to check for you later. If I have one its all yours.
Old Nov 9, 2017 | 07:51 PM
Ford77Pickup
Thanks man. Just let me know if u do and how much I owe ya for shipping. If u don’t then I’ll check with the shops above. Thanks!
Old Nov 10, 2017 | 04:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Ford77Pickup
I'm currently in the process of rebuilding my transfer case and one thing I noticed before tear down excessive yoke play in and out.
Upon further research, I found that apparently I am missing the snap ring the hold the output shaft and bearing together.
I'm about done with the rebuild and all I need is this snap ring and cannot find it anywhere.
This an F150 or F250, with part time or full time T/C?
Old Nov 10, 2017 | 04:38 PM
burnthelight88
Checked my stock and I do NOT have the snap ring you need. I have all the outer snap rings for the bearings though if you happen to lose/break one of those. They're in good condition.
Bill, that's the NP205, did they even make them in full-time? I thought the 203 was the full-time.
Old Nov 10, 2017 | 05:17 PM
NumberDummy
Parts catalog has two NP T/C pics, one for full time, one for part time.
Pics don't mention NP 203 or NP205, why I asked....because the pic will be necessary to get the basic part number of the snap ring.
There's probably a gazillion available NOS .. but there's also a gazillion different snap rings!
Old Nov 10, 2017 | 05:41 PM
Ford77Pickup
It’s an Np205 part time in a 1977 f150
Old Nov 11, 2017 | 03:02 AM
burnthelight88
The pictures didn't mention it because its the title of the thread ND. And yeah, you're not kidding about a gazillion snap rings. When I rebuilt mine I was missing 2 shims on the idler shaft, talk about a mess to locate.
I'm sure NumberDummy will hook you up with a part number shortly, sorry I couldn't be more help.
Old Nov 11, 2017 | 09:35 AM
Ford77Pickup
Appreciate the help guys. This is literally the only thing keeping me from having my truck back on the road.
Old Nov 11, 2017 | 10:22 AM
Jklnhyd's Avatar
Jklnhyd
I googled "ford direct drive np205 small parts kit". I found hits but couldnt verify sizes
Old Nov 11, 2017 | 12:10 PM
Ford77Pickup
I think this may be the right size I need. Just need to make sure it’s the right thickness. This one is thick but but not sure if it’s thick enough. I’m gonna measure the gap thickness when I get home this evening.
https://www.zoro.com/value-brand-ret...SABEgLutfD_BwE
Old Nov 11, 2017 | 04:02 PM
NumberDummy
It€™s an Np205 part time in a 1977 f150
See 7070 in upper pic. See applications (parts list #17C) for 7070 in lower pic.
Old Nov 11, 2017 | 04:13 PM
Ford77Pickup
Looks like a Company called A&Reds should have it. They are closed till Monday but their catalog has the snapring with the part number 02124518. I used the part number in the diagram above to find it. Thanks guys. I’ll update the thread Monday if this ends up being what I need.
Old Nov 11, 2017 | 04:22 PM
Ford77Pickup
Found it here as well. Thanks again
http://www.rearcounter.com/D3TZ-7070-C-parts190984.html
