2.7 ecoboost stalls, dies after towing
I had the same issue with my 2018 2.7 F-150. I hauled my brother's #6000 boat for him for a couple of hours and it did the stall and restart thing on the return trip from the lake to his home. There was no trouble on the way to the lake. It finally started to behave itself after I took it out of tow/haul mode and on the trip back home from Oklahoma to Arizona, there were no issues. I did notice that the tail pipe had blacked up...it has always been pretty clean. There was never any indication of overheating and the truck ran great. It sat down in the rear but handled well on the highway. I was a drivability tech for 25 years and I always get nervous when problems just fix themselves. I think I'll visit with one of the techs at the local Ford house.
I'll be following this thread with keen interest.
Cheers!
Warren
Cheers!
Warren
Well this is really playing with my head right now. We're getting ready to move my daughter across the state and I just rented a U-Haul trailer to do it. It's a 6 x 12 enclosed and will mainly have her furniture and a few boxes. I really doubt it will be all that heavy and it's only around 250 miles (should be around 4.5 hours as we are not taking any major highways, turnpike tolls SUCK!). I've never towed an enclosed trailer before but I suppose that really doesn't matter. If I have problems with this, I might well should re-think the 2.7. Seems like the problems are occuring after towing much heavier loads for much longer distances.
I’m sure your truck is fine, and will get you there and back without issues. Forums attract people with problems in search of solutions a lot more than happy owners.
The following users liked this post:
You can relax. Seriously, look at the timeline of this thread and consider just how many of these are on the road. The 2.7L EB is perhaps the highest volume engine for the best-selling vehicle in the nation. No matter how good the design, there are bound to be a few issues when they’re making that many of them.
I'll add my voice to the chorus. I know several people that have the 2.7L EB, and they have all been trouble free; including towing. There have been the occasional issues with towing that I've seen, and the ones that I'm aware of, there was an actual problem (cooling system blockage, intake, exhaust, ignition).
stall
I'm not sure if it would happen with the u haul. Smaller frontal area than my travel trailer. But it will happen on my truck every time under high load 70mph while towing. Now my trailer is 3900 lbs empty 4650 loaded. And I have to go 200 miles or so without stopping..will stall every time. Seems flooded. I can give it 1/4 throttle and it will run and clean up after about 2 min or so. No codes and no mods to the truck. Only had 3k on it when it started doing it. First time towing under those conditions.
Im having the exact same issue
My 2018 xlt 2.7 EB 4x4 has done the same thing as the OP. It did it the first time i towed my travel trailer. I took it in for service and they found nothing. Then I took the TT out again and was able to replicate the same problem. After towing about 4000lb for 1 hour at about 70 MPH the truck will shut off and will "require a manual restart".
The only way to get off the road is to start the truck, revving in neutral and slamming in into drive. No gauges show they are over heating. The truck was not showing any indication that something is wrong. It just turns off and displays a message "Manual start required" . The battery indicator flashes but i put a jump pack on the battery and it was still stalling if i didnt continue to rev the engine.
I took the truck to my dealer and they scanned it and found nothing. SO they put a capture device and of course while i have the event capture device the truck doesnt stall while towing. But once they take the device off I take my trailer to the coast and IT happens again.
Im ready to call it quits on this truck. The sole purpose of this truck was to pull that little ultra light trailer and it cant even do that. I just dont think its safe.
Currently the truck is at the shop and they cant even provide me a loaner. BS
My 2017 2.7 EB is having the same issue. Pulling my 8,500# camper across state last week I stopped to get gas and went to start my truck, it started up and then stalled. I started it again and it stalled. I started it the third time and had to keep my foot on the gas to keep it running the only light that came on was the battery light. This happened once more on the way there and another time on the way home. I even tried leaving the truck running on the fill ups and the truck would still die. Never had any issues when the truck was not towing for the week. No check engine light.Truck has been in the shop for a week and the dealer cannot find any issues.
Since the only light that's coming on is the battery, is it possible that the TT is somehow over-taxing the charging system? I know the larger engines in the F-150 have a mongoid alternator (over 200 amps IIRC), but I don't know what's in the 2.7L EB. Perhaps you could disconnect the battery in the TT and rerun the test? Just a thought.
#28
I just think if something was overheating or was a cause for concern it should throw some type of code or error to go off of. When the dealership tells me "nothings wrong" with my truck it really pisses me off. The truck pulls the trailer effortlessly and maybe thats the issue. Im almost ready to pull the plug on the EB and try and get into the 5.0.
#29
#30
