Sponsored by: Kumho
Wheel Centers/Question??
Old Sep 11, 2003 | 06:28 AM
truszip's Avatar
truszip
I keep losing the rear center caps off of my 97 - F350 4x4 with aluminum rims, (non-dually) as these are very expensive through the dealer were can I buy substitutes, or is there a substitute. Also would the center caps off of the newer trucks fit on mine? the caps looks like a better design as they fit over the actual bolts, might hold them in better. Thanks.
Old Sep 11, 2003 | 07:56 AM
nzabka's Avatar
nzabka
Try using some of that blue thread locker on the bolts that hold them on and tighten the you know what out of them.
Old Sep 11, 2003 | 08:08 AM
truszip's Avatar
truszip
Thanks for the reply, the caps on my truck are a press on fit with no bolts, screws or whatever holding them on. There's a spring ring on the inside of the cap that presses against four plastic tabs that push onto four out of the eight lug nuts which holds everything in place. Not a very secure design. I'm assuming that in time the spring ring/tabs loosen up and off she comes!
Old Sep 11, 2003 | 09:07 AM
nzabka's Avatar
nzabka
Ooopps. Forgot that the 250's have different wheel setups than the 150's.
Sorry I couldn't help.
74F100LGM
May 4, 2017 08:21 PM
truck7575
Jul 2, 2016 08:24 PM
relaurain
Nov 30, 2011 05:28 PM
klemn5
Sep 4, 2011 01:15 PM
chripark
Bronco II
Jul 12, 2003 02:11 AM
