Gear change
Old Oct 30, 2001 | 12:40 PM
mattv1's Avatar
mattv1
Gear change
If you change ring and pinion gears on a 1994 f150, does the speedometer need recalibrated? I've heard that the sensor reads off the ring gear and the speedometer will be accurate regardless of what gearing you change to. Does anybody know for sure?
Old Oct 30, 2001 | 12:48 PM
chris112lee's Avatar
chris112lee
Gear change
your speedo will need to be recalibrated.
Old Oct 30, 2001 | 01:38 PM
niteowl7's Avatar
niteowl7
Gear change
[font size="1" color="#FF0000"]LAST EDITED ON 30-Oct-01 AT 02:42 PM (EST)[/font][p]The sensor does read off the ring gear like you have heard. One revolution is one revolution no matter what gears you put in. What would cause the need for speedo cal is the changing of wheel/tire diameter. Hope this helps.
Old Oct 30, 2001 | 02:07 PM
mattv1's Avatar
mattv1
Gear change
I've got 32" tires. I have had the speedometer recalibrated for that already. Now I'd like to change gears. I read somewhere the OD ratio of an E40D is .67 does anyone know if this is correct?
Old Oct 30, 2001 | 07:03 PM
madman666's Avatar
madman666
Gear change
That is incorrect. The overdrive ratio is .71, also first is 2.71, second is 1.54, and third is 1.00; I know these are the correct ratios.
Old Oct 30, 2001 | 07:51 PM
Pastmaster's Avatar
Pastmaster
Gear change
Since you allready had the speedo recalibrated, then no I DO NOT think you would need to have it recalibrated for different gears.
1993 F-150
1989 F-150 4x4
(http://briefcase.yahoo.com/toydestroyer1)
Old Oct 31, 2001 | 04:47 PM
Donate52's Avatar
Donate52
Gear change
there is some formula to figure out if your speedometer is off or not, and by how much. if i find it ill post it. with my truck, when i put my 33" tires, the speedometer was off by 12%, then i switched from 3.08's to 3.73's and the speedometer is only off by 6% (roughly 5 mph or so, depending on how fast youre going).
Old Oct 31, 2001 | 05:11 PM
niteowl7's Avatar
niteowl7
Gear change
Donate52, What year/model truck? Digital odometer or no?
Old Oct 31, 2001 | 08:23 PM
madman666's Avatar
madman666
Gear change
Here is a formula for Speedo corrections.
You must use the actual size of the tire not what it says on the sidewall!
Take the new tire diameter and multiply that by your indicated speed on the Speedo than divide that by the old tire diameter.
Then what you have is your actual speed. EXAMPLE=
31.9 x 65 mph over 28.9 = 69.3 mph; as you can see it is 4 mph off, but if you are going 25 mph, it will be not off as much.
Does any one want any more formulas; I have one for determining at what speed (mph) you will be running at a certain rpm?
And I have one for determining RPM's at a certain speed.
And one for determining the gear ratio in your truck, if you don’t know.
And one for if you put bigger tires on, it will tell you what your gear ratio was reduced to.
And one for if you put bigger tires on, it will tell you the ratio you need to get back to your stock one.
And one for determining your crawl ratio.
Old Nov 1, 2001 | 12:00 AM
cpnhgnjnky's Avatar
cpnhgnjnky
Gear change
