Need help
Old Nov 6, 2017 | 07:38 AM
Jcskcs1's Avatar
Jcskcs1
Need help
Have a 1990 ford f250 7.3 idi. Changed the injectors out yesterday and have 2 or maybe 3 that are sucking air around the injectors or blowing bubbles if sucking wasn' t right term to use. I tried tightening more but was tight as I could get any ideas on what the problem could be.
Old Nov 6, 2017 | 08:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
did you put the new copper washers under the new injectors?
sounds like you used to old ones, or did not put the washers back under the injector.
Old Nov 6, 2017 | 08:57 AM
Jcskcs1's Avatar
Jcskcs1
I put new washers under the injectors and even re check myself and made sure the old ones were off, by looking at all old injectors and they were still stuck to old one.
Old Nov 6, 2017 | 11:21 AM
tjc transport
i ain't rite
ok. what did you torque the injectors to?
injectors should be 35 ft lbs torque.
Jcskcs1
Nov 6, 2017 08:10 AM
Bane270
Mar 10, 2014 02:56 PM
bashby
Mar 25, 2013 09:54 PM
Mach1
May 29, 2007 08:58 AM
Jerrod
Feb 20, 2006 07:33 AM
