Sponsored by: Real Truck
Electrical gremlin has me stumped
Old Nov 5, 2017 | 12:21 PM
Laidback81's Avatar
Laidback81
Hello all, I have a 2006 F350 I've been having electrical issues with since I bought it 3 months ago. I thought I had it figured out when I replaced the instrument cluster, however that only solved part of my problems. I have no dome lights or door chime unless the ignition is in the run position. Also, there is no power to the instrument cluster until the ignition is keyed in the run position. I have no power to anything in the accessory position and the truck seems to think the key is in the ignition even when it's not when I try to lock the doors using the inside buttons.
Old Nov 5, 2017 | 03:20 PM
Chuck's First Ford's Avatar
Chuck's First Ford
steering column wiring issues... or ignition key switch issues.
Old Nov 5, 2017 | 03:22 PM
Pocketlint's Avatar
Pocketlint
Did you buy a new cluster, a used cluster or a repaired cluster?
Old Nov 5, 2017 | 08:23 PM
Laidback81's Avatar
Laidback81
It was a rebuilt cluster from circuit board medics which I sèen mostly all positive reviews
Old Nov 6, 2017 | 06:24 AM
CircuitBoardMedics's Avatar
CircuitBoardMedics
Laidback81, we can definitely help you track the problem down. Please give us a call at 1-800-547-2049 so we can connect you to your order and work on troubleshooting this issue. We look forward to serving you soon!
Old Nov 6, 2017 | 07:41 AM
Pocketlint's Avatar
Pocketlint
And that's why I asked, some guys grab them from the wreckers but sometimes the wreckers have no idea if a cluster is good or bad that came out of a wreck. The guys at CBM seen this and I am sure they will try and help solve it with you. Let us know how things turn out.
wesayso
1997 - 2003 F150
15
Apr 10, 2022 05:51 PM
Fordguy05
Apr 11, 2019 12:06 AM
Shadowrider123
Dec 4, 2014 03:22 PM
cavyinthegarage
1983 - 2012 Ranger & B-Series
Jan 22, 2004 03:16 AM
wlavinder
Electrical Systems/Wiring
Aug 19, 2003 06:56 AM
