2004 150 Odometer problem
Old Nov 3, 2017 | 01:20 PM
dksac2's Avatar
dksac2
The odometer reading on the dash will go out. Unplugging the connector to the IP and plugging it back in (or remover the full time power fuse) will make it come back on for a short while then it goes out again (it may last hours or a couple days, goes out after vehicle has been shut off then restarted, stays out until power is interrupted to the IP). I've re done the solder connection on the panel and wiggling the IP panel, plug and wiring do not cause it to go back out again. I leaning towards a problem with the chip in the IP, but would like some advise on this before replacing the IP. I also have the problem where the gauges take a dump, all the lights on the IP come on, I get the buzzer sound, but it only lasts for about a second, then comes back on. Others have had these stay failed, not intermittent. All brake lights are working. Thanks in advance for any guidance.
Old Nov 3, 2017 | 02:19 PM
Franklin2's Avatar
Franklin2
It does sound like a faulty instrument panel. You can go to the junkyard and get another, but you will probably have to go to the dealer and get it programmed for your truck.
Old Nov 3, 2017 | 02:22 PM
dksac2's Avatar
dksac2
Thank You, there is a place www.circuitboardmedics.com that has repaired exchange boards for $150.00. They say they are pre programed (most likely from vin #). Do you know anything about them ?
Old Nov 3, 2017 | 07:05 PM
Franklin2's Avatar
Franklin2
I don't know anything about them. You could check with the local dealer and see how much they charge to program one of them. That plus the cost of a used unit versus the repair service.
I did a nationwide search using 2004 f150 only, and these came up. If you know if any more years would work, you could plug that in here Car-Part.com--Used Auto Parts Market and see if any more hits come up.
2004
Instrument Cluster(See also Speedo)
Ford Truck F150 -217K C 060-IA $85 LA Auto Parts USA-AZ(Tucson) Request_Quote 520-622-8922 Request_Insurance_Quote
2004
Ford Truck F150 INST. CLUSTER KING RANCH 194,208 MILES 316041 $75 Bailey's Used Parts USA-AL(Rogersville) E-mail 877-229-8816
2004
Ford Truck F150 INSFTF04 $50 TNA European & Domestic Auto Parts USA-TX(Grand-Prairie) Request_Quote 214-331-1000 /214-469-6115
2004
Ford Truck F150 INSFTF04 $20 TNA European & Domestic Auto Parts USA-TX(Grand-Prairie) Request_Quote 214-331-1000 /214-469-6115
2004
Ford Truck F150 B72458 $Call Best Auto and Used Parts USA-GA(Palmetto) Request_Quote 770-306-9000 Request_Insurance_Quote
2004
Ford Truck F150 W/ SHIFT INDICATOR 1076 $75 The New Country Auto Parts USA-IN(Indianapolis) Request_Quote 317-787-7555/317-787-5513 Request_Insurance_Quote
2004
Ford Truck F150 649514 $Call A to Z Auto Salvage USA-GA(Palmetto) E-mail 1-866-711-2869
Year
Part
Model Description Part
Grade Stock# US
Price Dealer Info
Old Nov 3, 2017 | 08:57 PM
dksac2's Avatar
dksac2
Thanks for all the info. As this place says the unit will be programed for my particular vehicle, I think it will be easier to go with them. Hope this fixes the problem....time will tell. Thanks again !
ITDave
2004 - 2008 F150
Aug 2, 2017 03:10 PM
Blaster900
Mar 8, 2017 09:11 AM
Adsltech
2004 - 2008 F150
Mar 20, 2005 10:06 PM
Vee eight
2004 - 2008 F150
Jun 1, 2004 12:07 PM
lmdew
Feb 18, 2003 09:45 PM
