Are exhaust brakes necessary or just nice to have?
I can understand how it can seem intimidating at first, since you haven't done this kind of thing before.
Honestly, 6% is really nothing to worry about. I seriously doubt you will have to drop more than one gear. You just don't have that much trailer weight back there. It's been many years since I drove that stretch of I-8 (like 30), so I don't remember if there are any tight curves on that road that you will have to slow down for. As long as you don't let your road speed get ahead of your road conditions, you will be fine.
As you approach the top of the hill, starting your descent, slow your truck to 55 and downshift one gear. Then start the descent. As you're going down the hill, you should not be gaining speed if your foot is off the throttle. That 6% grade, with your trans down one gear, at 55, you will probably have to keep just a light touch on the throttle to keep from slowing down. Remember, your trailer really isn't very heavy, so it won't be that huge of a push on you.
That is about "perfect" for a descent, light throttle keeps you steady speed, taking foot off throttle and you start to slow down slightly. If you have that, you're "golden".
And you will have a good chuckle when you get to the bottom, wondering what all the worry was about.
Yeah, im starting to feel a little stupid for even posting this up. in thinking it over ive been up and down that grade probably 75 times over the years. In hind sight ive pulled cab over campers while pulling sand cars and motorcycles with a much lesser tow vehicle. I think it is just the size that makes it seem worse than it is. Its a 2 laner with big sweeping turns. You could probably throw it in neutral and coast to the bottom if there wasnt other traffic. It really isnt an issue... And i should of thought this through better before posting.
And above all......enjoy your new to you camper!!!
You have parks that have an age limit for your rig! Wow, in the UK alot of residential parks have an age limit & rules like you must buy & sell through the owner of the park, but I've never heard of an age limit for tourers.
As for the grade question, was not dumb at all. You are planning ahead and making sure that everyone is safe when traveling. Nothing at all wrong with that.
No mountains in my area to contend with just tall bridges over the Mississippi River. I do like the option to use my engine braking system on my DRW F-350 towing my 15K pound toyhauler. I drove semi tanker trucks from 1972 to 1984 and never had any with engine brakes or even air ride suspensions. Semi trucks were still fairly primitive back then!
I would just add to make sure the trailer brakes are adjusted and operating correctly. I recently warped a rotor on my F-550 descending a 8% grade here in N.C. between Boone,NC and Wilksboro, NC.
I had not been in the mountains in a couple of years and was used to towing flat land. Coming down the grade I hit the brakes to scrub off some speed and realized that it was taking more pedal to slow down than I thought I should need. Eventually on the third braking event my steering started shaking and some noise, smell was coming from the brakes. After getting home I readjusted my trailer brakes. Three needed 10 clicks and the fourth needed about 20.
On the same grade my FIL was towing the same brand, length, and weight of trailer. He has a 2012 F-350 with all of the tow haul features. He used his brakes one time (I brake checked him unintentionally) the rest of the grade he coasted.
Think this brings us to the next question on brakes but think i had better start a new thread on that. Thanks for the well thought out and thoughtful replys.
Brake thread started: https://www.ford-trucks.com/forums/1...l#post17570791
#28
#29
Again you guys were right! The down hill was a nothing burger. I ended up putting it in 4th and the brake was tapped a few times to keep the rev's down under about 2300. Un believably easy and smooth. To be honest most of the drive i didnt even think about the 5er being behind me. I was very impressed with the trucks ability to tow a load. Thanks again
#30
