Road to Rocks
The Saginaw pump and the pitman arm will probably have to wait til spring. Mostly because it's usually dark when I get home now.
Pics to come of the new wheels. Mounted one on the front and it clears fine with the best 285/75 of the bunch. Need to mount 2 of the tires on the rims yet. They're like 11 inches wide!
Also, grabbed a fuel pressure tester today after work. Not thrilled with the results.
I wanted to get the numbers before I dive into looking for a vacuum leak, in chasing a high idle, and a falling flat on its face condition, whenever I want to accelerate. ***including revving in park as I did for below test***
So the chilton manual says koeo pressure should be 35-45psi.
Well the rear pump got to 35 after priming/cycling ignition 4 times. Starting at 30, then, 33, 34, and I stopped at 35 on 4th prime. After 5 minutes the gauge lost 5psi.
Front tank, same 4 cycles took me from 11 to 20 to 22psi with no change on the 4th prime. After 5 minutes the gauge lost 2psi.
Engine running, front tank pegged at 28psi, remember with a high idle, but no load really. Rear tank, 29/30 psi, pretty steady. Like I couldn't watch it change, but if I looked away for a short time, it would be on the other of 29 or 30psi.
On both pumps, if I stabbed the throttle, I could see the pressure raise to about 40, though it wasn't easy to see from the cab to get exact number. And once the load dropped, even if rpms were still up, (maybe 2k), pressure returned to the respective idle psi.
Not sure what to make of all that except that everything in the fuel system is old as dirt. I will look around in the tech section to figure it out but I do have a new tank and pump for the rear already in the basement. ***both tanks leak now. I can put a solid 5 gallons in rear and about halfway fill the front, and not smell any gas...***
The weird part is after I shut the engine off, the pressure rose 4psi on the front pump, and 7psi on the rear pump, both after 5 minutes.
This is in front of a LED bulb, I'm thinking 60 watt equivalent. I couldn't tell because when I unscrewed it, the base was so hot I could barely hold it. That was confusing...
Anyway I dumped this new water bottle seconds before filling it with the inlet side of the fuel filter. A lot foggy and kinda sedimenty. No change to throttle response with new filter but I was not expecting a miracle.
I think it's about an '84.
Miller thunderbolt AC/DC stick welder. 230a AC and 160a DC.
I need to get a 220 line for it, but my friend is an electrician and said yeah whatever, just let me know when. Now, bud. Now is when, haha.
:sniff sniff: Smells like truggy!
Measured the rear U-bolts so I can order replacements to use with the 1 ton blocks. I found a site called autoandtrucksprings.com and they ship 4 grade 8 U-bolts with tall nuts and washers in a hefty 5/8ths diameter for $60. $18 less than I paid for the 9/16ths front U-bolts I bought at the local spring shop. Turns out ATS is on the way home from my job, ish. Can be, anyway. I don't know any reason not to use them for the bolts. Has anyone within the sound of my voice heard anything bad? They're grade 8 so, ehh?
Next I finally got the stupid yoke off the front of the T/case. Replaced it with the 1 ton jawn, chased the threads in the double cardamom joint. That was iPad spelling... I've had numerous people tell me it's a double cardigan joint as well. Anyway double cardan joints are a funny thing. Didn't pay it any mind until today and it's just neat is all. Right so, bolted in the front driveshaft after mounting a buttery smooth 4wd shifter. I feel like the driveshaft and t/case yoke should have gotten some blue loctite, but held off for now. I'll climb under and check the shaft bolts in a few miles and see what's what.
With the "axle swap" now complete besides the pitman arm, I switched gears again to the engine bay. I've been looking into diagnosing a bad catalytic converter. Decided to have a look at the plugs due to their age, not mileage. They were all gapped where I left em several years ago, and mostly white, down in the spot where you "read" plugs. In quotes because the reading is pretty much set in the first quarter mile of driving. Some corrosion outside the head and I had a new set ready to go so I screwed em in and set off to heat up the cat. No change in drivability, as expected.
What Ive been seeing is that you should expect about 350 degrees Farenheit, at the weld ring before the cat and like 500 at the weld ring after the cat. I dug around for the laser temp thingy I've had for years and found a 9 volt battery for it. Hopped in, drove about 10 miles and got it to temp. Which brings me to another issue. Normal for my truck is the first line of N in Normal, on the gauge. I think I might have put a cooler thermostat in when I did the water pump and everything that freaking touched it fiasco like 5 years ago. Or, I definitely replaced the rad cap with a 7psi version slightly before that to minimize water loss which was, frequent. I still have that cap because of a weak core plug, and I'm not sure about the thermostat...
Anyway, and sorry for all the words and no pics if you've made it this far...
I got the truck to my normal temp and checked the cat for heat. What I got was like 415 at the front and 500 out the back. The common thing between all the people doing heat readings was about a 150 degree difference, inlet to outlet. I'm not sure what this means for me, as I've said, thermostat/cap could be fiddling with my engine temps, cat could be clogged. Not sure what to use for a back pressure test. Thinking I could just axe the whole system and put the headers and a full exhaust on with a newer, non air injection style cat.
Kind of just putting it all down on paper right now. Certainly open to helpful criticism or direction.
anyway the trucks have been back burner for sure. I left for Georgia late in march for some training and have been back home training on the job for about 6 weeks. soon i'll finish training and either have zero time on my hands or zero money.
I did meet a fellow F series guy yesterday who inspired me to check the tps voltages on my 250. I was wondering how important it is for the engine to be warm for those checks. it wasn't... and my readings are far from how a good tps should read according to easyautodiagnostics.com tps test. where I should have the sweeping voltage from .9 to 4.5ish at idle to wfo, I get a reading under .9, which decreases slightly when I open the throttle. assuming that's a good enough place to stop the test, I wish to pretend some gremlin there also prevents a reading where I should have 5 ish volts between the orange wire and battery ground, which I believe is the signal from the ecm. the 11-12 volts between the tps ground/batt pos is present. these are all through freshly poked holes in the insulation with a fluke auto ranging dvom.
ill try again tomorrow after I warm the engine.
that website tells me I'm either not getting power from the ecm, or theres a short or bad connection.
I took the propane torch out to check for vacuum leaks since that seems like the easiest method. didn't find any, but I did forget to check near the pcv valve, or the vac reservoir. I'm off til Saturday though so I'll get back out and try again tomorrow.
looked a bit at testing the iac, and decided to remove and clean that. saw it should have 7-13 ohms between spades and show offline(on the meter) from each spade to iac body. good test there. before I removed it, I unplugged it while the engine idled high as usual. rpms did drop significantly and it ran rough but never stalled as I've read it should. but I read just today that it should just kind of keep chugging, so I don't know which is correct. anyway, cleaned out the iac as best I could with throttle body cleaner, being careful not to drown the solenoid end. it was gummed up for sure. plunger moves pretty freely now where I think it could have been stuck partly open before. dried it with compressed air, remembered reading I should have unplugged the battery already, did so, reinstalled the iac and let the keep alive memory die.
meanwhile I knew it had been some time(not miles though really) since the k/n replacement air filter had been serviced. took care of that. left it out to test out the iac though as it takes forever to deal with that cleaning/drying/oiling malarkey. and my basement smells like cat **** now from the cleaner which is a mystery.
during the 15 minute idle period where the ecm relearned how to idle, the rpms varied some as expected, but eventually settled at a pretty reasonable sounding level. I havent put the tach cluster in yet but maybe i'll do that tomorrow as well. it is definitely an improvement over a dirty old motorcraft iac so I'm sure we're moving in the right direction. letting it cool off now and i'll run back out in a bit to restart the truck, see if it's still holding that improved, lower idle.
for giggles, after the 15 minutes I whacked the throttle to see if all my problems were magically cured. no such luck. still a mean hesitation with any real amount of go pedal.
oh, yesterday I pulled codes because I haven't in a while. 111's for koeo and continuous memory. 172 for koer. O2 sensor lean. no check engine light, just thought i'd check, and there was one in there. so I'm reading that can be caused by some other issues besides the actual sensor. since my fuel pressures are less than stellar, I think i'll wait to be concerned with that 172, until after the pumps and tanks are replaced.
After conferring with my new Bronco friend I mentioned the other day, explaining how gunky the IAC was, he convinced me to clean the throttle body. I asked if he thought my lack of reference voltage warranted a new TPS or if it could be a different issue. His response was that it'll be easier to do now than to take the throttle body off a 2nd time and replace later. I ordered a Motorcraft unit for tomorrow.
Got down to the throttle body bolts before the bugs became an issue with the worklight and shorts and really, I should have been out there all day instead of screwing around doing nothing. Anyway, I opened the throttle plates to find plenty of gunk inside. and what looks like enough built up, to keep them open just a hair. Like 1.09vdc at closed on the signal wire. I guess I fibbed yesterday about the signal voltage. At closed it's 1.09 and wfo is 4.6+vdc. That may be acceptable, I don't know. I had the meter out to make sure I really couldn't find the reference voltage and wouldn't you know it, 3rd time's a charm! I checked the plug 1st to see if there was a poor connection and maybe that was the problem. Maybe my probe didn't hit the wire before. I could see copper, but I tried in a more accessible spot, and there was my correct reference voltage. I'll keep it around after I replace it tomorrow.
I also didn't, DO NOTHING all day. I finally got around to installing the tach cluster. I have a 93, and a 94 sitting here but couldn't trust that I'd written 93 on the correct one. I did, but I wanted to make sure so I plugged them both in. both do everything except, as I read here before, the 93 cluster somehow prevents the battery from charging. Switched my speedo section into the 94 tach cluster, cleaned it all up, good to go. I would like to find a nicer cluster cover. I had foggy and scratched to choose from. Went with scratched.
1025ish rpms at idle. I'm guessing it had to be at 1250-1300 before cleaning out the IAC.
Picked up 2 felpro TB gaskets and considering reinstalling after cleaning, before picking up the new TPS, just to see if the gunk is my real problem. Almost feel it'd be a disservice to the community if I didn't do that. We'll see how much my feelings affect what actually happens though.
Found and bought a timing light on Craigslist. it came with a remote starter, compression tester, and this whacky box I think its called a scanalyzer. 80's craftsman product. All still in the boxes with instructions and shiny. Guy had used the timing light a few times and the rest is like new. $20
Timing light works as good as the one I borrowed recently and with the thingamajig removed, I was able to confirm base timing is set at 10* btdc. With it installed, and running at the improved 1025ish rpms, but also at the previous higher than that rpms, the timing is at 20*btdc. seems like a lot for just a few hundred rpms over what should be idle. Any thoughts?
I'm wondering if the hesitation is really being caused by the poor fuel pressure.
I need to find out where I'm really supposed to be idling...
Receiver had to come down. 6 bolts, looked nice and easy at a glance. A better look revealed the bolts were of the carriage persuasion, and not a square hole in sight. Not sure who, how, or why someone would use carriage bolts in that manner. But anyone involved, I hope they hurt themselves. 4 of them were easy to reach with the South Philly Grips. Some folks call those vise grips...
5 and 6 were behind the rear most cross member, tucked in a corner. I struggled on both, not wanting to resort to a heavy spark producing tool. Yet. Finally got the passenger side head tightly gripped and spun off its nut. No luck on the driver side. Gave up for the night.
Conferred with a friend and decided, screw it. If working on my truck is the way I go, then at least I died doing something I love. Out came the cut off wheel this morning, and shortly after, so did the bolt. Made it through about 3/4 of the bolt and nut close to the frame, and the bfh handled the rest.
Took a buy wheels for the Flare Side break, over in Jersey. A set of 16x10 American Racing dulled aluminum buncha-holes. I'll try to get a pic up soon. $125, no major rash. Need a polishing bad, but money well spent in my opinion.
Came back and the tank came down pretty easy. Only had about a gallon of fuel in it, as I've known this day would come. Struggled with the fuel line disconnects for an hour, cut the ends on the pump side soon after. No trouble wiring it up, less trouble getting it all back together, went for a food/gas run. Ate, dumped surprisingly ALL of a 5 gallon Enviro can into the new tank, cycled a few times... and it fired up so fast I nearly didn't let go in time before I imagine the starter would have began to cry.
Put a gauge on the fuel rail, 30psi at ignition, idles at 30, jumps to 40 with throttle, holds 30 after shut down. Rechecked the front tank while I was there. 20 at ignition, idles at 29ish, shakily jumps to 40 with throttle, and also holds 30 after shutdown. I noticed the stumble still, on both tanks, but much worse on the front.
Anyway, after watching friends replace pumps on different vehicles, I was dreading having to rewire the harness. So I left it long and still need to weatherize it. Felt like a king when it fired up and the gauge worked and all. Maybe I'll look for a front tank soon. Has to be easier. And I would really think about lifting the bed to do the rear tank if I ever need to in the future. My neck is killing me now.
