C-6 Control Lever
Old Nov 1, 2017 | 12:45 PM
BainbridgeBrewer's Avatar
BainbridgeBrewer
C-6 Control Lever
I am looking for a 78', C-6, 2WD, manual control lever. I know from my parts catalog that I need p/n D8TZ-7A256-A. I found a lever on Ebay with an EOTZ-7A256-B tag on it. Are these interchangeable? All I seem to find online is some obscure info, maybe relating this to a 90 - 93 C6. Any indeas? worse case I go to the not so local JY and start wrenching on a 79 I've been picking at for a while. Thanks for the help.
Old Nov 1, 2017 | 12:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BainbridgeBrewer
I am looking for a '78 C-6, 2WD, manual control lever: D8TZ-7A256-A = 1978/79 F100/350 2WD C6.
No Ford dealer or obsolete parts vendor has any.
No!
EOTZ-7A256-B = 1980/89 F100/350, Bronco & Econoline C6.
Old Nov 1, 2017 | 06:14 PM
72rtchallenger's Avatar
72rtchallenger
I ran into this once years back after buying a c6 out of a scrape yard and figured it was out of a car and I added some length to the rod coming off the column as the picture shows and could take back off if needed,,this worked for years with no problem this was on a 79 f150,,might help if all else fails
Old Nov 1, 2017 | 08:32 PM
BainbridgeBrewer
Thanks ND for the confirmation. They look similar but I couldn’t tell if it would work. I’ll Pull the correct one from a JY donor.
Crop Duster
Sep 11, 2017 01:17 PM
circlecityrabbit
Feb 9, 2017 08:47 PM
Choppermike
WTB - Parts & other
Aug 15, 2016 07:29 PM
1974F100
Jul 27, 2008 08:07 AM
erikl85
Mar 14, 2003 01:05 AM
