Sponsored by: Real Truck
Replace ball joints
Old Sep 10, 2003 | 08:37 PM
99f350sd's Avatar
99f350sd
Replace ball joints
I'm right in the middle of my ball joint replacement , Locker and all the seals in the front axle. I thought it was gonna be harder than it was. It was pretty straight forward. All the seals were trashed the bearings are good and the U joints are good so I'm happy. The locker went in now since I had the axles out. The diff came out easy maybe alittle to easy but I think it will be fine. I'll be making a tool to install the big seals tomorrow and install my new brake splash sheilds.. It sure helped to have the right tools I bought ball joint tools and a tie rod puller. The master kit has all the spacers and adapters you could want. That and the press cost about $100.00 and you should have a good air gun...
Oh and edlebrock shocks
Dick
