1992 E40D Problem
Old Sep 10, 2003 | 08:11 PM
rforster's Avatar
rforster
1992 E40D Problem
I have a 92 F-150 that developed a rumble or chatter that could be felt in the accelerator pedal. This problem seem to be at its worst when in traffic after shifting into OD and slowing to 40 to 45 miles an hour and then accelerating slowly. This is when the rumble or chattering could be felt, untill it shifted down to third. Eventully it could be felt between other gears. I had changed the TPS as I was told to do and that this was the problem in most cases. This did not work. I had the tranny rebuilt last week by a certified tech establishment and it seemed fine for two to three days and now the rumble or chattering as I call it can be felt again. It is coming back and getting worse. Two questions,
1. Can the problem be more in the computer than in the tranny, because the tranny seems to be fine in all other areas. BTW the tranny really needed to be rebuilt 175000 miles and slipping.
2. When I originally replaced the TPS I threw the original away and there are 5 different ones available, how can I find out which one I had on there. NAPA says I need the original numbers from it.
Thanks
Ray
Old Sep 10, 2003 | 11:24 PM
tankhokie's Avatar
tankhokie
1992 E40D Problem
ray,
i have the same year bronco w/e4od....
hmm does that rumble/chatter seem like it is the engine trying to get more power when it is in od, then finally shifting into od?
my experience is that is normal in driving on hills and such when in od.
but your description seemed more harsh (chattering)
have you checked to see if all your cylinders are firing? maybe a bad plug wire??
Old Sep 11, 2003 | 12:41 AM
dieselzen's Avatar
dieselzen
1992 E40D Problem
Ray,
I don't know why NAPA says there are five part #'s for the TPS. Perhaps their looking at the ECM (electronic control module), of which there are actually six different ECM's and part #'s. There is only one part# for the TPS in my docs, and it is:
F6TZ-9B989-AA
Regarding the TPS, when you installed the new one, did you adjust it to make sure it was sending out the proper voltages to the ECM? Are you sure the techs who rebuilt the trans. made sure the TPS, and all the other sensors, were sending the proper voltages? Before replacing the current TPS, I'd have your techs make sure the voltage signals being sent are right. If you are going to do it yourself, send me an email at:
thecabin@datasync.com
and I will send you a zip file which will include test procedures for all of the sensors along with other E4OD stuff. R.A.
Old Sep 11, 2003 | 06:34 PM
rforster's Avatar
rforster
1992 E40D Problem
I did not realize that there were any adjustments that could be made on the TPS. I cant remember seeing any place to adjust it.
As for the engine, it is running fine. The top side was just overhauled and tuned and working great. That 4.9 straight six is a tough @#$@#$.
Thanks for the responses.
BTW today the problem is now being felt in 3rd shifting back to second just like the OD to 3rd.
Old Sep 11, 2003 | 10:15 PM
kinglg's Avatar
kinglg
1992 E40D Problem
I know this might seem like a dumb question, but did they replace the tourqe converter when they did the rebuild? Sounds to me like classic T/C chatter.
