Rough Idle ..
Old Sep 10, 2003 | 08:07 PM
gpball5150's Avatar
gpball5150
Question Rough Idle ..
I've had a '78 F150 (351) for about 6 months now. It's been running great. I put it in the garage a couple of days ago to work on the brakes, and now it's idleing really rough, stalling, "bucking" and tonight, the muffler got cherry-red hot and glowing. I can't figure out what would have happened so quickly. It's got a new carb, plugs, wires, distributer cap. Any ideas? I'm really frustrated. Thanks!
Old Sep 10, 2003 | 08:17 PM
Copycat's Avatar
Copycat
Rough Idle ..
check your exhaust pipe for a potato (just kidding) nothing else comes to mind right now.
Old Sep 10, 2003 | 08:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Rough Idle ..
How many miles on the engine and has the timing chain ever been replaced?
Check and see if the ignition timing is way off, if it is the timing chain may have jumped a tooth.
Old Sep 10, 2003 | 10:28 PM
Mil1ion's Avatar
Mil1ion
Rough Idle ..
Is there a plugged Catalytic convertor on that truck ?
Place you hand over the exhaust pipe opening to feel how much
is coming out.
The have someone rev it up while your hand is still there.
Old Sep 10, 2003 | 11:31 PM
Jerrybo66's Avatar
Jerrybo66
Rough Idle ..
My guess goes with Torque1st.... To get my clunkers through emmissions I used to retard the timing as far as possible and still run ...That causes fire to excape the cylinders before the gas is completely burned... The result is fire and heat all the way back through the exhaust, making a longer burn, eliminating pollutants..... At least thats the therory I have why it worked...
