Joying Radio Interference - Remote start / Door locking issues
Old Oct 27, 2017 | 09:50 PM
seijirou's Avatar
seijirou
Ah, interesting. I actually feel a bit silly now that it didn't occur to me that the radio causing interference and you wanting to use a remote start should be mutually exclusive.
Old Oct 28, 2017 | 02:52 PM
05MilMachine's Avatar
05MilMachine
They keep it powered because Android. When doing shorter trips and errands, it comes on instantly vs having to boot each time. Also, the radio station presets sometimes disappear from mine when powered all the way down. Perhaps they have cured that issue in the later versions though
Old Oct 29, 2017 | 06:11 AM
unleashd's Avatar
unleashd
With the switched power to the ACC wire, the radio functions just like you've mentioned above. It will turn on within 2 seconds of the key turned in the ignition and be fully functional. If I disconnect the harness completely and remove all the power to the unit, it does lose the settings, radio stations etc. But, it does not forget the wi-fi, BT connections.
Old Nov 14, 2017 | 07:21 AM
EddieEX10's Avatar
EddieEX10
Originally Posted by jcthorne
A Pioneer Android Auto unit and could not be more pleased with it. Just works very well and the android integration works great, the maps are easy to read and OK GOOGLE works as it should.
I am thinking of installing an android stereo. Which model did you use? Thanks!
Old Nov 14, 2017 | 07:23 AM
jcthorne's Avatar
jcthorne
Pioneer AVH4200NEX
79sparky
Mar 22, 2015 12:50 PM
Iaff113
Mar 16, 2014 11:50 AM
booesq
Jul 29, 2013 07:06 PM
jrcbfun
May 13, 2007 09:23 PM
