Corrosion Prevention Between Panels
Old Oct 25, 2017 | 01:15 PM
Connecticut Calvin's Avatar
Connecticut Calvin
I'm getting ready to paint and install my NOS fenders on my 1956 F500. I'm curious to know what you guys are using to make a little cushioning between body panels to prevent any rubbing through which in turn causes rust; the areas I'm thinking in particular i.e. where the fenders bolt to the cab or the inner fenders or where the fenders bolt to the gravel pan.
Old Oct 25, 2017 | 02:39 PM
RingoRaintree's Avatar
RingoRaintree
I'm using plain old fender welting. glued on the fenders and gravel pan first then bolted to the body. I would have had numerous small gaps without it and I think it looks just right. The piece they sell for the front fender to cowl was way too thick. Welting can also be had in colors. On the inner fenders to the outer I used hockey stick wrap Got the welting and the stick wrap at Amazon.
Old Oct 25, 2017 | 05:59 PM
EFranzen's Avatar
EFranzen
I haven't got that far, but I'll use Friction Tape between the inner and outer fenders to sort of match what was removed.
Old Oct 25, 2017 | 10:04 PM
jcslocum's Avatar
jcslocum
Haven’t heard “friction tape” in a while. The issue with most welting, is it can/will trap moisture and cause rust.
Old Oct 25, 2017 | 10:36 PM
Mervy49's Avatar
Mervy49
Interesting. I would never thought of hockey tape for that application, and I have lots of it on hand thanks to my son the hockey player.
I've used it for other stuff and it weathers good, it doesn't absorb moisture.
I've got rubber inner tubes that I was thinking about cutting to match the running boards to the fenders.
Old Oct 26, 2017 | 10:03 AM
Connecticut Calvin
I bought rubber washers to go between the panels where the bolts line up but it's not a true seam. I like the idea of hockey tape. Clever. There's also rubber tape that I've found which might work too. Here is the link to Amazon's product page.
https://smile.amazon.com/Neoprene-Ru...ds=rubber+tape
Old Oct 26, 2017 | 04:02 PM
petemcl's Avatar
petemcl
You mean corrosion like this?
For the '48-'52s there is a rubber gasket but as you can see it just rubs through the paint. I have been debating about not putting anything in there. Just leave it open, but I think that the splash from the wheel well would be significant . . . if I ever drive it in the rain.
In short I would be interested in a better solution too.
Old Oct 27, 2017 | 08:13 AM
Connecticut Calvin
Ouch! Did you have the standard rubber gasket between the fender and cab?!
Old Oct 27, 2017 | 09:23 AM
petemcl's Avatar
petemcl
Yes, when I bought the truck the gaskets were in place.
Old Oct 27, 2017 | 11:05 AM
52 USCG Panel's Avatar
52 USCG Panel
The cowl area was pretty rough on my truck too--fenders rusted as well. There is a big gap between the panels, however, so some sort of filler is needed. I'm using the usual, original type, rubber gasket. If there is something better, I'd like to hear about it.
Jim
pweng1
18
Aug 20, 2021 08:40 AM
DPESQUIRE
Apr 22, 2007 05:23 PM
Christopher2
Dec 15, 2004 05:31 PM
Chippen
Jul 23, 2004 12:25 AM
