pining and knocking NEED HELP
What I have done is
1.change all 8 spark plugs to bosh platum plugs
2.did 2 motorvacs (is supposed to clean the fuel rail injectors and all carbon out of cylinders)
3.ran 2 cups of water into a vacuum port to get rid of carbon
4.used 10 – 20 bottles of chevron fuel system cleaner
5.ran a 3m total fuel system cleaner kit ( does upper intake and throtel plate)
6.changed the fuel filter
7.changed the PCV valve
8.remover the octane spout plug that retards the timing 3 degrees
9.took out the MAF and inspected the little wires to make sure there was not crap or carbon on them
now this is everything I can think of to do I am out of ideas and I need some help. I pretty sure it is not carbon because I think I have ran enough cleaners to get any carbon that might be in there out.
the only thing I could think of is the O2 sensor but it is not cheep from ford so if anyone know how to test it let me know and I will. I need the pin out because it is a 4 wire heated sensor and I do not know what wires do what.
PLEASE SOME ONE HELP ME I DO NOT THINK I CAN TAKE THE PINING AND MORE IT IS DRIVING ME CRAZY
[B]I have a 1994 ford ranger with 90,000 miles 2.3l 4 cylinder with a 5 speed manual
What I have done is
2.3 4cyl......all 8 spark plugs.........did i mis somthing here?
any way, did you try pulling the codes? checking the timming? fuel pressure? EGR valve? Just a few things to get you started. DW
