Log on to myford.fordvehicles.com. On the left side will be some menus. Click "Resources and References." When the list appears click on "Owners Guide." When the page opens click on "Download Owner's Guide." That's all there is to it! Good luck.
Michael
It is necessary to have all (maximum of four — original and/or new) of your remote transmitters available prior to beginning this procedure. To program the transmitters yourself:
Insert a key in the ignition and turn from 3 (OFF) to 4 (ON) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4 (ON) position. The doors will lock/unlock to confirm that programming mode has been entered.
Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.)
Repeat the previous step to program additional remote transmitters.
The doors will lock/unlock to confirm that each remote transmitter has been programmed.
When you have completed programming the remote transmitters, turn the ignition to 3 (OFF) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
