There is an inner A Pillar 14 Ga stamping that will need work in the hinge area if it is rusted like this one. No one makes that either.
No one makes the inner cowl panel inside the truck.
If you are any bit handy with fabricating it is pretty simple to do as it is just layers.
Note: Even getting rust free stuff form here does not mean it is truly rust free. I repaired a 64 cab with rust free parts form a spare cab i have. They had quite a few pinholes i had to repair. So beware, Most of the really good stuff from here is ling gone.
In the first picture, the lowest rust hole below the rubber gasket, what is this called in the replacement panel world? I need this. And who sells it?
Thanks
The closest place to both you fellers that will cut parts off and ship them is Flashback F100's - Home
He probably has the parts you need, but keep in mind he is a capitalist.
