Who would've thunk it?
Old Oct 22, 2017 | 07:52 PM
Thoth88's Avatar
Thoth88
Yesterday (Saturday 10/21/2017) both my horn and cruise/speed control went out. Got home and proceeded to start checking fuses, funny I could find no fuse for the Cruise/speed control nor horn in the owners manual inside fuse box . Took off driver side air bag to check connections and was good, even attempted to jump the horn contacts and got nada. Thru the Factory service DVD I identified the 'Battery Junction Box' location for the horn relay and horn fuse. Now here's the interesting thing, the horn and Speed control are supplied thru the same fuse . 15a fuse was burned and replaced, got my horn a speed control back
Old Oct 23, 2017 | 03:00 PM
Poker4me007's Avatar
Poker4me007
Just curious what vehicle it this? glad it was an easy fix for you...
Old Oct 23, 2017 | 06:12 PM
Thoth88's Avatar
Thoth88
2001 Ford Explorer Sport Trac
Old Oct 24, 2017 | 09:51 AM
Ranger Bob's Avatar
Ranger Bob
Proof reader must have been sick the day they sent the manual to print!
Good info! I'll do the same and mark it in my owners manual.
Old Oct 30, 2017 | 11:55 AM
'88 E-350's Avatar
'88 E-350
Most owner's manuals have the interior fuse box layout and under-hood fuse box layout on different pages and I've seen people miss one or the other.
Old Oct 30, 2017 | 06:06 PM
Thoth88's Avatar
Thoth88
Had I an owner's manual I wouldn't have had to search the interwebs. In the pdf I found there is no listing for the speed control fuse.
Old Oct 31, 2017 | 07:02 AM
shorod's Avatar
shorod
There is a listing for the speed control fuse in the owner's manual, but it's not on the same circuit as the horn. It's listed as fuse 10 in the passenger compartment fuse panel (7.5A, page 163). The horn is on fuse 22 in the Power Distribution Box under the hood. That agrees with the factory service manual wiring diagrams which confirm the speed control is NOT on the same fuse as the horn. However, the horn is an input to the speed control since the speed control will disengage if the horn is pressed. Apparently the horn needs power though rather then the speed control just looking for the signal to be grounded when the horn button is pressed.
So ultimately the horn and speed control are not on the same fuse, but the speed control will not work if the horn fuse is blown. The fuses for both are identified in the owner's manual. This connection (pun intended) between the horn and speed control was an interesting find.
-Rod
andy9743
Jun 15, 2016 05:25 PM
92AeroStarVan
Aerostar
Nov 9, 2004 04:19 PM
g00ru
Electrical Systems/Wiring
Jul 14, 2004 04:51 AM
03f150man
1997 - 2003 F150
Mar 19, 2004 07:08 PM
Mr. Whiskers
Jan 10, 2004 08:26 PM
