Need Help Trouble shooting engine
The engine will crank, but not start.
I put a OBDll scan gauge on it and it gave me a code of PO420
I checked the fuel reset button and it was OK. I wanted to check the fuel fuse but cannot open the door to the panel under the hood to do so. I do not want to pry on it for fear of breaking the door or lid. Is there some special thing to do to unlatch it? It appears that this engine has the I think it is called the Cap or Cop ignition system. (coils on spark plugs) I am not familiar with this system. I am trying to trouble shoot the system to find out why it won't start. Fuel system, Ignition system and Oxygen. Any help appreciated.
Mel
Air is easy, make sure the filter is clean and all the tubing to it is clear. MAF sensor in the air cleaner box needs to be connected and clean. All the tubing from the filter to the throttle body MUST be sealed.
For fuel the first easy thing to do is test for pressure on the fuel rail at the engine. There will be a Schrader valve on the shiny chrome looking fuel rail on the engine. Try to start it a couple of times then push on the Schrader valve to see if any fuel squirts out. If it is working right it should be enough fuel to catch you on fire so use a rag or something and don't smoke. Or better yet put a fuel pressure gage on that Schrader valve to check the fuel pressure. Should be 30+ psi to start it. You should also be able to hear the fuel pump run for a couple of seconds when the key is first turned on.
The coil on plug or COP system has a coil on each plug instead of a single coil pack for multiple cylinders. This results in a stronger spark. To check for spark, pull off a coil that is easy to get to (7mm socket), stick a spare spark plug on it, ground the plug, and have an assistant engage the starter to see if it is firing.
Mel
Mel
Mel
Check for voltage at the inertia switch, that way you can split the fuel pump power circuit in half. Remember that the fuel pump only runs for a couple of seconds when the key is turned on. You might try banging your fist on the fuel tank while someone else operates the starter. Sometimes that will jog a failing pump into running.
Laying there right next to the fuel tank you should hear the pump prime when someone turns on the key.
Fuel filter is under the truck, slide under driver door area and you should see it. The filter requires a special tool to unfasten the hose connectors.
I will check the voltage at the inertia switch.
I sprayed Starting fluid on the air filter and the truck started right up, so it is a fuel issue. I would think that the fuel pump would be running as long as you are cranking the engine.
I will try banging on the tank while cranking the engine. They are made of plastic. LoL! I ordered a new filter and filter removal tool from Amazon. will be here Monday.
If I have to change the fuel pump I will probably remove the bed rather than dropping the tank.
Thanks for your help and info. will keep the forum posted as I progress.
Mel
As far as when the fuel pump runs, it primes the rail to build up pressure for a couple of seconds as soon as the key is turned to run. And then the fuel pump stops. After that the PCM looks for a signal from the crank position sensor to see that the engine is turning. If that signal (engine is spinning) is there, then the fuel pump engages.
The power distribution box under the hood has one latch as shown. Using my left hand, I wrap a finger around the back edge and curl the finger upwards.
power distribution box latch 2003 F150 V6
You first need to eliminate the PATS as a possible cause of a no start.
Turn on the ignition and let it set at least one minute to see if the THEIFT light flashes a code.
If yes what is the two digit code. It will be the cause of a no start.
If no code, proceed to test fuel pressure at the test port on the fuel rail.
To do the test, cycle the key to ON several times and check the pressure that should develop. It should be about 35 psi and hold at least 10 minutes with the key OFF.
Do these checks before going to a lot of labor, to find out what is the exact trouble.
Obviously, start fluid that causes the motor to run indicates a lack of fuel.
Is it the PATS or the fuel system or even both.
How the fuel system works:
Key to run causes the PCM to ground the fuel pump relay for about 3 seconds then drops out. This is normal operation.
Once cranking begins the PCM re-operates the fuel pump full time to pressure the fuel rails.
You need to use common sense based on how the systems work in general to see where and what the failure might be.
Otherwise confusion reigns.
You bought a truck with unknown history so need to go about trouble shooting with some order and expect other issues to appear as time goes on..
Good luck.
Mel
Good luck.
Mel
Thanks again
Mel
You will not get the pump to run by cranking the engine over with a no-start.
One reason is possible flooding that could happen if there is no ignition.
Repeated key cycling will run the pump each time.
This is the way to re-prime the injection rails if you run out of fuel and put some in the tank to get going again.
Cranking after the initial key on likely will not cause the PCM to turn the pump on.
The program monitors the RPM just 'above' the cranking level from the key on short time pre pumping for engine firing before actually turning the pump on. (same as if you spray fluid in the intake) for testing.
Cycling the key on several times give you most all the info you need except flow volume.
You must understand these 'little' things because they are engineered into the system operation for a reason.
Most just think turning the key on runs the pump full time.
Doesn't work that way.
Another big reason is a fire hazard. In event of a crash the inertia crash sensor is there to stop the pump from feeding a fire by shutting it off.
This is on all vehicles with electric fuel pumps.
What you want to know does the pump run and does it produce the required pressure.
Good luck.
