out of the blue I was backing into my drive way and it started running ruff. As I Start off driving it shudders until the second power band is hit then it stops until I need to add a little peddle to maintain speed. If I need more power to get up a hill it vibrates hard until the second power band is reached (around 2000rpm) and the turbo kicks in then it stops until the rpm's drop back below 2000. What can this be??
