302efi to 351w carb swap
Is the 86 an auto? Are you gonna keep the automatic trans? If not then get the proper flywheel, otherwise get a shifter, like you didn't know that. Pretty much a drop in deal you will have to disconnect the efi pump but other than that pretty straight forward. Give the starter and igniton proper power and ground.
