2016 F350 headlight upgrade ?
My work location has been changed where I have to drive 26 miles of unlit back roads at night. As you all know, the stock headlights in these trucks suck. With that said, what is my best option between sylvania silver star ultra, sylvania silver star zXe, or putco silverlux led's? I don't want to change my headlights, just the bulbs. Thank you in advance!
Years ago I put the silver ultras (I think) in - weren't really any better other than the light was a bit whiter. They blew out after two years, so I just stuck the oem bulbs back in
supposedly upgrading the headlight wiring harness to a heavy duty one connected to the battery gives off much better light. Supposed to be an easy upgrade, but I've never tried it though.
You don't need a bulb upgrade, you need a headlight upgrade together with a good led kit for the fog lights.
You could do do these without paint or halos and get some money off
https://www.hidretrofitkit.com/product/2011-2016-ford-f-250-f-350-f-450-f-550-black-custom-bi-xenon-hid-retrofit-headlights/
https://vanquishauto.com/hid-headlights/h1-va55-xenon-hid-conversion-kit.html
and matching fog lights
https://vanquishauto.com/hid-headlights/9145-g55-xenon-hid-conversion-kit-led-super-bright-replacement.html
Use coupon code SAVEME20% at checkout
Problem with led kits right now is that the lows turn off when the highs turn on and the highs shoot up to the trees. You literally loose all the light upfront. the low beams give out a lot of glare vs the hids and the hids are 3x brighter than leds as tested.
https://vanquishauto.com/led-comparison
Superbrightleds.com.
It's the 30" slim single row. They have a labor day sale going on right now, 15% off with labor17 code.
I made my own brackets for the ends and ran the wiring through upfitter #3.
I swapped out my stock headlights with these 6000k LED lights and new housings. WOW, what a difference. It's like daylight in front of the truck.
I used these in my 2008......I did both headlights and fog lights ...very impressed with them......
https://www.ford-trucks.com/forums/1...t-upgrade.html
Low beams are great, high beam seems to brighten things up at a higher level.
I have no regrets and love the black-out on the upper part of the headlight casings. As my brother said, "That truck looks Bad A**",
and to think I just purchased it to pull our RV.
:P
:P
