Low Oil Pressure
Old Nov 2, 2001 | 12:59 PM
ront's Avatar
ront
Low Oil Pressure
Hi Guys,
For the last couple of months my oil pressure gauge has been reading a little low. One of the guys at work(who does alot of work on his own Fords) has told me that it seems like a faulty gauge because when driving down the Freeway at a level speed, the gauge will move up and down. The last few days it has been staying pretty low, but I notice nothing else No lack of power, no decreased gas mileage. I know that the best thing to do would be a mechanical gauge and hook it up and see what the true pressure is, but I can't really afford to get one right now. I am just wondering what other signs I may look for if I have a real problem with the oil pressure? Any help would be greatly appreciated. Thanks
Old Nov 2, 2001 | 06:37 PM
beratte's Avatar
beratte
Low Oil Pressure
Actually your gauge is little more than a glorified idiot light. It is not a gauge at all. The sender is a switch that closes at 6psi (according to the 1995 Ford truck factory manual) and then sends a signal through a resistor to the gauge. It will give you a middle of the road reading and may vary a little bit over time but means nothing. Like you said you should get a quality oil pressure gauge to determine the real pressure. According to the book the 5.0 should have a hot oil pressure of 40-60 psi at 2000 rpm. Here's what the book has to say about it: "The oil pressure switch controls the magnetic oil pressure gauge's pointer position. The oil pressure switch closes under normal engine operating conditions (oil pressure above 42 kPa [6 lb/sq in]). The oil pressure switch opens with the engine (6007) off and no oil pressure."
Best of luck, Ben
1995 Bronco XLT, 302, E4OD, 31" BFG AT's
Old Nov 2, 2001 | 08:08 PM
Pastmaster's Avatar
Pastmaster
Low Oil Pressure
A member on here described what he did on his own truck to make the dummy guage a real guage, by doing a little splicing and rewireing. I'm real interested in learning how he did that!!!
1993 F-150
1989 F-150 4x4
(http://briefcase.yahoo.com/toydestroyer1)
Old Nov 4, 2001 | 10:40 PM
pross's Avatar
pross
Low Oil Pressure
unless you really want to know exactly what the pressure is, just replace the sender unit on the block. about less than $10. These do go out or cause erractic readings....
Old Nov 4, 2001 | 11:19 PM
beratte's Avatar
beratte
Low Oil Pressure
You have to do more than just replace the sender, there is a resistor that is attached to the instrument cluster flex circuit that prevents it from giving a max reading. About 1/2 way on the scale is the most you'll ever get unless you remove the resistor.
Best of luck, Ben
Old Nov 5, 2001 | 05:14 PM
nmaineron's Avatar
nmaineron
Low Oil Pressure
