03 6.0 missing
Old Oct 9, 2017 | 04:50 PM
Rubidon's Avatar
Rubidon
03 6.0 missing
Hi guys!!
I am trying to figure out a miss in my new to me 03 6.0. I have a Snap On Solus Edge scanner so I can find any infomation you guys need to help me with this. What i have so far is
FICM voltage is constant at 48.5-49 volts.
I disabled the injectors one at a time and recorded the drop in rpms if that would help. I also did a cylinder contribution test also but not sure what i was looking at. Between all cylinders the difference was a high of 2 with a low of -3 in the 4k frames or milliseconds or whatever it reads.
Old Oct 9, 2017 | 04:52 PM
Rubidon's Avatar
Rubidon
I also did the buzz test and all eight injectors where audible with not much difference in pitch.
Old Oct 9, 2017 | 05:20 PM
Per4mance's Avatar
Per4mance
Well looks like you need a FICM. FICMrepair .com is a good place to get it done. Check your batteries individually and your Alt too. Ill bet thats the root of your problem. Check your fuel pressure too while your at it. Welcome to FTE!
Old Oct 9, 2017 | 05:49 PM
Rubidon's Avatar
Rubidon
Sorry it is 48.5-49 volts, fixed origianl post. On a scanner like mine what is the oil pressure?
Old Oct 9, 2017 | 06:19 PM
xcrsp440's Avatar
xcrsp440
Are there any trouble codes present?
Old Oct 9, 2017 | 06:37 PM
Rubidon's Avatar
Rubidon
The only codes are for thr egr and that has been deleated. They removed everything for the egr.
Old Oct 10, 2017 | 09:21 PM
BLADE35's Avatar
BLADE35
Have you tried a bubble test
Old Oct 10, 2017 | 09:35 PM
navistarnut's Avatar
navistarnut
Good call, sometimes it's the last and best resort.
Old Oct 11, 2017 | 07:40 PM
Rubidon's Avatar
Rubidon
I will have to google that one.
Old Oct 11, 2017 | 08:03 PM
FiznUKa's Avatar
FiznUKa
The bubble test is fairly easy to do.
Remove the top fuel filter and cap next turn the key to the run position but do not start and fill the fuel bowl with fuel almost to the top you can watch from the driver seat between the hood and cowling. Unhook the starter wire from the passenger side fender near the hood hinge. Use that wire to turn the engine over using the stud on the positive terminal of the PS battery. As you are turning over the engine watch for any bubbles that may pop up in the filter housing. If you have bubbles you have an injector/s that’s gone bad.
Confused yet
Old Oct 12, 2017 | 07:28 PM
Rubidon's Avatar
Rubidon
When I do this where do you go after,if, i get bubbles?
Old Oct 12, 2017 | 08:21 PM
FiznUKa's Avatar
FiznUKa
If you have bubbles even very small in the center of the filter housing is the stand pipe. Remove it and in the bottom there are two holes one for each side of the engine. Which ever hole they come out of the injector/s will be on that side of the engine. Next you will move onto removing the glowplugs one by one. By that I mean remove the front glowplug on whatever side is the problem side and retest for bubbles. If the bubbles stop that will be the bad injector.
Old Oct 12, 2017 | 08:37 PM
FiznUKa's Avatar
FiznUKa
Run6.0Run explains it better
Old Oct 13, 2017 | 06:06 PM
Rubidon's Avatar
Rubidon
Ok thanks guys, I have to work this weekend so it might be a week before I can get to it.
The object of removing the glowplug is to let the compression go out the hole instead of up through the injector?
Old Oct 13, 2017 | 06:15 PM
FiznUKa's Avatar
FiznUKa
Yes the exhaust/pressure is being pushed through the injector back into the fuel bowl so when you remove the glowplug it will release the pressure through the glowplug hole instead of the damaged injector.
