Studs
Old Sep 9, 2003 | 09:58 PM
whistler's Avatar
whistler
Studs
Not the guy kind either...
I understand why 2X4's are not actually 2"x4". I do not understand why pre-cut studs are 92 5/8" long. Could somebody explain this to me.
Whistler
Old Sep 9, 2003 | 10:19 PM
Vanhecht's Avatar
Vanhecht
Studs
i think its to fit between a 2x4 header and footer and be exactly 8ft tall....maybe i'm wrong
Old Sep 9, 2003 | 10:23 PM
Mil1ion's Avatar
Mil1ion
Studs
I guessed aksed this all the time.
Have a look here.
http://barelybad.com/fp_selectstuds.htm
Old Sep 9, 2003 | 10:41 PM
Bubba Shrimp's Avatar
Bubba Shrimp
Studs
1.5" for the bottom plate plus 3" for the top two plates plus 92 5/8" for the stud = 97 1/8" or 8' 1 1/8". 8 feet of the wall is covered by sheet rock, leaving 1 1/8". This is taken up by the ceiling sheet rock and flooring. It gets a fuzy about here as that won't make up the whole 1 1/8". I did read that any gap left over would be put at the bottom and covered with the baseboard. Perhaps a real carpenter can explain it more fully.
Old Sep 9, 2003 | 10:43 PM
Mil1ion's Avatar
Mil1ion
Studs
Drywall /sheet rock is always lifted about 1 /2" above the floor
That's why you put the ceiling sheet & top sheet in first.
Old Sep 10, 2003 | 12:01 AM
Colossus's Avatar
Colossus
Studs
Not to mention, a 2x4 can be literally a 2x4 - when it's rough cut. Then they do the finish cut - and what do ya know - its a lot smaller. I should know, our garage is built in the '20's with this REAL lumber...Makes the new stuff look like toothpicks...
Old Sep 10, 2003 | 03:06 AM
Torque1st's Avatar
Torque1st
Posting Legend
Studs
The modern saw systems don't even cut the 2x4's to 2x4" any more.
Old Sep 10, 2003 | 11:41 AM
Colossus's Avatar
Colossus
Studs
Unless you go to a mill...Sometimes the big home-improvement places around here will carry them, but you can't build anything with them because they are not to code - they are too big
Ford79
19
Oct 27, 2005 09:48 AM
Vankaye
28
Feb 26, 2005 12:53 PM
maticuno
30
Dec 20, 2004 04:00 PM
dcexplorer
Dec 10, 2003 11:59 AM
